I NEED SERVICE IN MARYLAND
   / I NEED SERVICE IN MARYLAND #1
SCOTCHERS
Bronze Member
Fallston , Maryland
PT-425
ANYONE AND EVERYONE THAT MAY KNOW A NEARBY POWER-TRAC SERVICE PROVIDER I'D LOVE TO HEAR. I LIVE IN THE SYKESVILLE AREA 21784 ZIPCODE. I'M AT AROUND 100 HOURS AND WANT TO KEEP HER FRESH AND HAPPY. PLEASE HELP.
   / I NEED SERVICE IN MARYLAND #3
I don't believe that there are any service centers for the Power-Trac.
These machines were made to be operated and worked on by the owners. What the owners can't do, there are service centers for the engine you have, and a hydraulic shop should be able to fix any hydraulic problems. Terry at PT can just about talk you through any problem. A good friend with mechanical skills is a plus.
If you need help, just ask the question, and I will bet some one on this forum will have an answer for you.
I believe that this forum could qualify as the actual service center for PT.
I'm currently suppose to bleed and change the hydraulics and hydraulic filter at around 50 hours and never done this. I have 85 current hours. I've been very diligent about the greasing and cleaning and air filters and oil. I have a lot of reservation on 'bleeding out the air'. It appears it's like draining oil and changing filter however, the bleeding out the lines makes me hesitant. I'm also concerned with a small grinding noise as I steer back and forth right and left as i'm driving only. Aside from these few issues, she's wonderful. Maybe I just need my hand held once. Thanks for any help John
   / I NEED SERVICE IN MARYLAND #5
John...there is no need to change the hydraulic fluid(motor oil) but you are overdue for the filter change(I belive this is a warranty issue also??)...it's not as difficult as you imagine and once you've done it you'll wonder why you waited to change it. The spare filter should have come with the "bleeder "hoses. Would suggest you search this forum for the filter change and bleed topic and you'll find a wealth of tips that will assist you...good luck and be sure to change those filters (engine and hydraulic) on a regular basis. I too have apprx the same hours as you and am looking at changing my motor oil over to synthetic at 100 hours.
   / I NEED SERVICE IN MARYLAND #6
There is really no need to SHOUT.
   / I NEED SERVICE IN MARYLAND #8
Click on this link and read it a few times. Then read your manual a few times. Then call PT and ask them if this sounds right. Then do it. /forums/images/graemlins/grin.gif
You will be just fine. It all sounds complicated until you finally do it. /forums/images/graemlins/smile.gif
   / I NEED SERVICE IN MARYLAND #9
</font><font color="blue" class="small">( There is really no need to SHOUT. )</font>
<font color="red"> /forums/images/graemlins/confused.gifDidn't you hear his post!!??!! He is 'CALLING' for help!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/smile.gif</font>
   / I NEED SERVICE IN MARYLAND #10
</font><font color="blue" class="small">( Click on this link and read it a few times. )</font>
/forums/images/graemlins/confused.gif <font color="red"> Will 'this link' work for folks with them newfangled Robin engined models!! </font> /forums/images/graemlins/confused.gif /forums/images/graemlins/smile.gif
Loftness Mulching Head (A51573)
Loftness Mulching...
KUHN SR110 GII LOT NUMBER 39 (A53084)
KUHN SR110 GII LOT...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
