I need help:
   / I need help: #1
FRIZ
Bronze Member
NW Indiana
John Deere 4720 Cab
I need help::confused:
I am city slicker who bought 78 acres of land. And I am smart enough to know that I know nothing. My contractor made sure that I bought the right chainsaw, STIHL 290 with safety equipment chaps, gloves, helmet and so one. He took me along for one day to introduce me to operating the 290. Thatç—´ how bad it is.:eek:
But before I ask my tractor question, let me give you some information:
The land is in the Midwest, mostly flat a few slight elevations. Most of it is wooded, approximately 10 acres are meadow, which has not been mowed in 2008.
Two ponds, 1+ acre and 0.5 acre, both with trees and grass around it.
The house has also trees and grass around it.
Approximately 800 yards of gravel road.
Approximately 1 mile of hiking trail which will be expanded.
I have identified four immediate tasks for the tractor and some possibilities for the future:
1. Cut grass around the house and pond. (mower deck)
2. Collect leaves around the house and pond. (bagger)
3. Clear the gravel road from snow. (snow blower)
4. Transport stuff from A to B. (utility cart)
Future possible tasks:
1. Maybe mow the 10 acres of meadow
2. Maybe drag trees out for firewood
3. Maybe lift heavy stuff and take it from A to B
I have looked at the following tractors.
John Deere X749
John Deere 2305
John Deere 2320
John Deere 3320
Kubota BX2660
Kubota B2320
Kubota B3030
The John Deere X749, John Deere 3320 and Kubota B3030 can have a factory cab. The John Deere 2305 & 2320 can have a Curtis aftermarket cab. All cabs are available with heat. But only the John Deere 3320 and Kubota B3030 are available with A/C. which would be great considering Midwestern summer heat and mosquitoes.
All tractors have 4 wheel drive but only the John Deere X749 has 4 wheel steering, which would be great for mowing around the house and pond with all those trees.
John Deere has two interesting utility carts (18 cu.ft. & 21 cu.ft.). Kubota has no utility carts.
The John Deere X749 is perfect for the four tasks. But cannot be easily adapted to new tasks and has no A/C.
John Deere 2305 I find unattractive.
John Deere 2320 is very attractive. But can it mow efficiently around the house and pond with all those trees? And it has no A/C.
The John Deere 3320 is too big, isn稚 it?
Kubota BX2660 & B2320 are not bad but no cab, to the best of my knowledge.
Kubota B3030 is very attractive. But can it mow efficiently around the house and pond with all those trees?
There are two friendly John Deere dealerships nearby (8 miles, 35 miles). Both are willing to negotiate price.
All the nearby Kubota dealerships (35 miles away) belong all to the same owner. And I have not found a salesperson I ç”°lick with.
John Deere will come to do maintenance (for a reasonable fee) at my property. Kubota will come to pick the unit up for a 途ansom?
I just don稚 know what to buy.
Am I looking at the right manufactures and models?
Am I too obsessed with 4 wheel steering and/or utility carts and/or A/C?
Do I have to buy two tractors? My wife will not be amused!!!
PLEASE help with constructive criticism and with your experiences.
Thank you,
Regards,
FRIZ (the clueless)
   / I need help: #2
Welcome to TBN, From what I see you could use 2 machines. A smaller machine for your yard maintanence and a larger machine for working your pasture and woods. 78 Acres is a fair amount of land and a larger machine will do you justice to maintain the larger area. I'm biased to JD but the any of the major brands are good. I can't recommend anything for the yard but for the larger tractor I'd look at something in the 60+ PTO HP.
Good luck.
   / I need help: #3
I agree. I would get a nice commercial ZTR like a Ferris or Exmark. Plan on spending 7-8K for one of these then you will need a to see what other task you want it to handle and go from there. I use my mower to chop the leaves, just run over them twice and they are gone in a few days.
For the tractor I would look at the 30ish Hp size with a good FEL and then pick up a good box blade, a 7' grader blade, and a decent medium duty bush hog. Get AG R1's tires on this machine not the Industrial R4's they push so hard. I can not see you needing 60Hp unless you plan to farm with it. I would not use a snow blower on a gravel drive. The rear grader blade is the way to go. Some even get a snow blade to go in-place of the bucket on the FEL for the winter months. A bucked is not a very good way to plow snow with but can be helpful if major drifts or piles need to be moved.
As for the cab its just a matter of preference. If you plan on keeping those trails cleared its going to take a beating. It would be nice in the summer and winter months but I just do my chores in the morning and evening and have been fine. There are also many nice days in the spring and fall where it will just get in the way. The spring and fall is when I find myself doing most of my work and the rest of the year is just maintenance and playing.
By the way where are you located. I see you said midwest but where? I live in Northern Indiana where things are totally different from where I grew up in Southern Indiana. For example we get 2' of snow blizzard once or twice a year plus plenty of 6" snows in between but just 150 miles south where I grew up we are lucky to get 12" of snow the whole year.
Chris
   / I need help: #4
1*John Deere X749
John Deere 2305
John Deere 2320
John Deere 3320
Kubota BX2660
Kubota B2320
Kubota B3030
2*only the John Deere X749 has 4 wheel steering
3*John Deere has two interesting utility carts (18 cu. ft. & 21 cu.ft.). Kubota has no utility carts.
4*The John Deere X749 cannot be easily adapted to new tasks .
5*Am I too obsessed with 4 wheel steering and/or utility carts and/or A/C?
/////////L . B ./////////////)
1*This is the only garden tractor on the list and way to little tractor to handle the task you listed.
2*That's fine if all you plan on doing is making turns in tight circles,
All wheel steer is not automatically an asset as it can also be a liability .
3*That should not be considered in evaluating Kubota vs Jd .since carts can be purchased anywhere from anybody ,
Lots of guys here have built their own.
A cart/ trailer adds or subtracts no value to or from a tractor.
4*Such as handling a tiller FEL front blade or back hoe.
5*That's my take.
L . B .
   / I need help: #6
   / I need help: #7
I would just buy a decent lawn mowing yard machine. Probably a used one, but I'm so tight I squeak when I walk. Then get a used tractor with front end loader. In the 40-90 hp range. Oddly enough, the longer you have and use tractors, the smaller they get. At first, you will think that a "tractor" like those X749's are "big" but after a couple years they become pretty dinky. Same with a machine like the B3030, it just takes longer. The bigger the land, the faster that happens.
I would also say that you don't need to be in a big hurry to buy anything right now. The economy is in the dumper and it looks like there will be at least 4 years of hard to extremely hard times ahead. If you have the $$ now, you could wait till spring. Or you could even put a "wanted" add up in places like craigslist for used. And give lowball offers.
If you have little mechanical aptitude, experience or time you may be better off getting new or slightly used. Can't tell from here how it swings.
In the 40hp and down market, Kubota is the standard of excellence. In the 40-90 range, JD is in that spot, with Kubota nipping hard at the heels. Others like Ford / New Holland are good too.
   / I need help: #8
I do 3 & 4 on your list with my Kubota B3030HDSC (cab model). We get 15 to 30 feet of snow each year, so I mainly got it for snowblowing although I used the FEL to put in a new rear entrance to my house. I also use it for wood chipping and hauling and processing firewood. My yard is quite small so I have a small power mower. I couldn't imagine mowing around a house with the B3030 however, collecting leaves possibly. It is too big and bulky for mowing in tight spots. It would probably be great for mowing acres of grass. I think the rest of the posters are right, you need two machines.
The heater is very nice but I never imagined I would use the air conditioner, but I did quite a lot this summer. As you said it gives you protection from the nasty biting, and other annoying bugs.
   / I need help: #9
john_bud pretty well nailed the important considerations - 78 acres is a fair bit of work with the different kinds of projects you outlined.
And when you've worked on your place for a spell; the tractor's do get smaller and the projects have a way of "expanding"!
I don't know how refined a look you want regarding the lawn, trees, etc. near the house. If you want the "estate" look - you'll need a dedicated lawn mower. Maybe a zero turn.
A 10 acre meadow/field, a mile of trail to maintain and expand, 800 yards of road to grade, plow and resurface and you'd like a cab with A/C.
I'd think you'll need to start looking at machines at 45hp pto and up. The Kubota Grand L40 series are super machines as are the 4000 series cabbed JD's.
The L5240, L5740 and the 4520 and 4720 from JD would handle the projects you've got in mind. However, those machines would translate into a sizeable cash outlay. Even good used machines - a zero turn mower and a cabbed 45hp tractor with brush hog mower, FEL and rear blade would likely run somewhere close to $50K.
Or, you could compromise (everything is a compromise...) and take a look at the smaller cabbed JD 3720 with a rear or mid mount finish mower. Forego the dedicated lawn machine and use the 3720 to mow the yard as well as the tougher jobs.
Take your time. Demo a couple of different machines. See if you can use one to mow with (next year) and go from there.
Best of luck.
AKfish
   / I need help: #10
just a quick note how is it bad, that it took you one day to learn how to operate your chainsaw?
When you do your chainsaw liesence over here its a 5 day course.
As for the tractor issue, what is your price range?
2018 GMC 2500 4x4 Crew Cab (A52384)
2018 GMC 2500 4x4...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51691)
2017 Mack GU713...
2025 K1119 UNUSED Metal Carport (A53117)
2025 K1119 UNUSED...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
Case CX80C (A50123)
Case CX80C (A50123)
2003 Ford Ranger XLT Pickup Truck (A51692)
2003 Ford Ranger...
