I need help with the forums.
   / I need help with the forums. #1
masscity
Platinum Member
NW UP of Michigan
L3540HSTC-3 B7100DT Ferguson TO-35
Before when I completely read a highlighted post it would lose its highlight.
Also when someone added a comment to a post it would put me at the new comment, instead of at the beginning of the post again.
I've tried many things and I can't seem to get it back to the way it was.
The only change I've made is I upgraded my Norton Internet Security.
Ed
   / I need help with the forums. #2
Are you sure you are logged on?
When something happens and I lose my auto login, all the messages are like new and I've not seen them. When I log on, it comes back as normal.
Being logged on works even when you use multiple pcs. It "remembers" for you if you stay logged on.
Hope this helps.
ron
Hope this helps.
ron
Thanks for replying. I checked and I am logged on. Sometimes in the past I would lose my logon, but I noticed something was different and I would logon again and everything is fine.
I've had computers for years, but I don't know that much. Might be my old brain.
Ed
SET OF (2) DELTA DUMP TRAILER SWINGING DOORS (A51244)
SET OF (2) DELTA...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
New Calf Hut (A50515)
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
