I need help with 9n ?
   / I need help with 9n ? #1
Douglas733
Yucaipa, Ca
Ford 9N, Ford 640, Stihl Farm Boss,
My tractor will not run without me holding the choke out about a half inch if I let go of the choke it immediately stalls if it's on the lowest idol then it'll plod along but any type of higher idol I have to have the choke out what do you think my problem is
   / I need help with 9n ? #2
Sucking in air some where, you need Sound Guy.
Ohhhh Sound Guyyyyyyyy??????
   / I need help with 9n ? #4
try this.. screw main needle into the carb and count turns.. unscrew same amount. try that.
if no go.. back out a lil more.. but not over 2.5turns.
if still nada.. either fel needle is blocked and makeing her lean.. or as said.. you may have a vacume leak leaning her out.
post back.
( is this a ms tsx 33 carb ( 241 variant ) or? )
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
