I need help finding the fuse.
   / I need help finding the fuse. #1
DonWorrell
Pleasant View, TN
Mahindra 3325
I posted the following message a week ago. I am now trying to fix the problem.
"My 3325 will be 3 years old July 2009. I put a new battery in the tractor a month ago. I put in what was called for by the manufactor. It started and ran well.
I went out last evening and tried to start it. I put everything in netural turned on the key all the lights turned red as they should. It turned over once or twice or about 2 seconds then it went dead. All the lights and gagues are dead.
What could possibly be wrong?"
In the replies I was told to see if I had headlights. I don't have headlights so my problem now lies in lose cable connections, a bad battery, bad switch or the fuse someone spoke about.
My question is where is this fuse located?
Any help will be appreciated. My tractor runs out of warranty July 6th so I want to set it fixed before then just incase it is somethig more difficult.
Thanks,
Don
   / I need help finding the fuse. #2
Sounds more like a bad electrical connection. It can be on either the pos. or neg. side.Check your connections at the battery, then trace the ground to it's home on the chassis. Make sure all connections are clean and tight. It could also be at the starter solonoid, where the pos. cable from the battery is fixed.I don't own your brand tractor, so can't help with the fuse location, but the fuse is seldom the problem. Hope this helps :confused:
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2025 K0608 UNUSED 3-Rail Style Fence Panels (A50860)
2025 K0608 UNUSED...
2015 Hyundai Elantra Sedan (A48082)
2015 Hyundai...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
2017 Chevrolet Tahoe SUV (A48082)
2017 Chevrolet...
