I need help deciding HP needed
   / I need help deciding HP needed #1
tonydga
McDonough, GA
None
I am in the market for a tractor with front loader, but I have no idea what hp I need. The major uses for the tractor will be to level about 3 acres of land and redo a dirt drive and clear out some brush. I know that I will need a box blade, but what hp tractor is powerful enough to level land with a box blade? I was thinking small like 24hp, but someone told me I needed 50hp.
   / I need help deciding HP needed #2
How big of a rush are you in? How deep are your pockets? ($$$$) You can use a small tractor, it will take longer but you can get it done.
   / I need help deciding HP needed #3
You need a bulldozer for a few days AND THEN get a tractor sized for maintenance.
   / I need help deciding HP needed #4
How capable a tractor is is defined by its WEIGHT.
Most Georgia soil is pretty tough stuff. Ground contact work requires quite a lot of tractor weight.
Based on minimal information provided I suggest a tractor with bare weight of 3,000+ pounds. A tractor of this weight can pull/operate a Box Blade with a weight of 120 pounds per foot of width, which is what it takes to cut tough dirt.
Bulldozer first may be a good idea.
I'm not really in a rush to completion but in a rush to get started at least to see some progress so that I feel like I'm making a difference, if that makes sense. As far as $$$, I really wanted to stay under $15,000. I found a 2004 John Deere 790 with 300 hours for $12,000. I believe that is about a 30hp.
   / I need help deciding HP needed #6
Don't buy for temopary need. Rent or hire for that. I have a 91 motor hp with fel and it has great lift capacity. However it is oversize for working in our yard. I use it but will not fit in tight areas and unless dry will leave tracks. Think on your long term use and buy for that.
   / I need help deciding HP needed #7
I used to own a John Deere 750. John Deere 790 is a very sound, uncomplicated tractor.
It would be fine for maintenance after heavier equipment did your leveling. The Deere 790 is too light (2,000 pounds, bare tractor) for leveling work.
Here are the specs for the Deere 790: TractorData.com John Deere 790 tractor information
Some were 2-WD, some 4-WD. Know what you are inspecting.
   / I need help deciding HP needed #8
Follow the NEWBURY advice!
Hire somebody with a dozer for a few hours.
Then you can trim it up with a tractor pulling a box blade.
IF you get 30+HP you can pull a 5' box blade, if the Georgia red is not wet.
   / I need help deciding HP needed #9
The someone who told you you need 50hp for 3 acres like to spend your money! Most HP is used for implements like brush hogs, mowers and farm equipment. For ground engagement work like the BB the weight of the machine have a bigger impact.
Under $15,000- try Mahindra eMax or 1526, Kubota B series, Kioti also makes solid machines. Typically you pay a bit more for Kubota and JD.
The implements you buy will be sized for the machine you purchase. A 50hp tractor may have a 7' box and a 25hp machine may have a 5' box.
   / I need help deciding HP needed #10
50hp like you have seen would blow your 15k away and ask for 15k more lol.
My buddy has a 28Max with a backhoe and FEL, it's a 2013 model I believe, it's a very stout machine but only weighs around 1800lbs I think.
The problem that you face is, your expectations are really high for a little machine, my buddy with that 28 max did the same, within the first week he talked about trading it off for a bigger 1538 tractor because the 28 max couldn't lift chunks of concrete sidewalk for him.
So far he still has it but my point is that these little tractors are little lol they will get the job done VERY slowly.
I have a 4320 which is 48hp at over 5k lbs and I wouldn't think it would be very useful for heavy ground work, I feel even at its weight would spin tires with the R4 tires.
To get a smaller tractor to pull harder Tires, Weight and 4x4 is very important, R1 tires are gonna pull hardest and turf prob the worst.
Grading existing drives, a land plane is very effective, faster and more efficient than a box blade but the box blade digs better on new ground.
If I had to dig deep in soil I would buy a 2-3 bottom plow and disk, fastest way to dig up soil with a tractor I feel, plow to dig, remove dirt with FEL and smooth with a 6-8ft disk.
I have never graded with a tractor but that's how I would approach it.
2008 New Holland L175 (A47477)
2008 New Holland...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2023 G Bar K Skirted Hauler Bed (A55218)
2023 G Bar K...
