Ballast I need Front Ballast solutions
   / I need Front Ballast solutions #1
hill
PNW
'07 KuBoTa B7800 and Jinma 254
I've got a Jinma that I can't drive with anything on the hitch. It's OK brushhogging our 4 acre field even though it steers with the brakes or like a battleship at sea but for any use where I need to steer better than that the front wheels are way to light to turn.
I rigged up a mickeymouse addition of about 100 lbs. that did help some but I'm ready to buy something commercially made for the purpose.
Who sells such stuff? I need leads, and if not local then low cost or free shipping would be good, obviously.
   / I need Front Ballast solutions #2
I would make me a weight bracket and then buy some suitcase weights locally to fit. Ken Sweet
   / I need Front Ballast solutions #3
Which Jinma is so light in the front? Maybe a good excuse to add a FEL. :) :D
Yeah, I wouldn't mind a loader for it but I don't come around to the idea that spending as much as the tractor cost just for a loader is worth it because I've got a loader on our other little tractor.. I bought the Jinma 254 for $4000. brand new from an equipment surplusing site in Seattle. (How could I pass that up?:rolleyes:).
I use it to run a chipper and have cut that field with it but it's really light up front with the brushhog on it's tail. Just enough to not be steerable and makes cutting the lumpy field of ours difficult. There's a ditch through the middle of the field that's all grown with berries now and I'd like to be able to drive nimbly enough to back the cutter into the ditch up and back repeatedly for it's length. The way it is now would take all summer to do that..
I really don't know anything about what weights are available commercially, and worse, I don't know what it would take to hold down the front end with anything weighty on the hitch. It drives around fine with no implements at all but what use is that?
   / I need Front Ballast solutions #5
any type of hang on chin weights can be added with a simple vertical bar up front to hang them off of.
that or just start welding 4' sections of railroad rail to the front as a bumper.
   / I need Front Ballast solutions #6
Good thoughts all...good guys on TBN, aren't here? (except sweettractors...he's shifty).
Another thing to look for is cast iron free weights. You see them on Craig's List and normally very cheap. A couple 50 or 100 lbs weights will work fine.
(just joking about "sweettractors" Ken Sweet...he gives great advice)
   / I need Front Ballast solutions #7
Also saw used counter weights from elevators mounted as front end ballast - they have two holes in them and stack very nicely since they are about an inch thick and rectangular in shape.
   / I need Front Ballast solutions #8
If you could find some old VAC Case front tractor wheel weights, they could be made work inside the front rims. I have also filled front tractor tires with fluid to add ballast. Works really well on bigger 4x4 front tires. Ken Sweet
   / I need Front Ballast solutions #9
The least expensive way would be to fabricate a box for the front and load it with sand. Some 1" plywood subflooring should work as long as there is some metal reinforcement for attaching to the tractor and underneath the box. Just bolting the plywood to the tractor's frame would likely tear out in no time.
Or a load concrete pier blocks in an open box. Like one made (welded) out of heavy re-bar.
A metal box would take some welding and fabrication and should be removable if a FEL is ever under consideration. Maybe a neighbor could do it if you don't have the means.
   / I need Front Ballast solutions #10
When I don't have an attachment on the rear, I use a 5 gallon bucket filled with sand as a ballast to my FEL. You could probably rig something similar on the front.
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
2011 Cadillac SRX SUV (A50324)
2011 Cadillac SRX...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Toro Z Master Mower (A50324)
Toro Z Master...
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
