ajflyfishing
I would like to add a indepentent hydraulic pump on my CK25 to run a cutter bar. I don't know much about hydraulics. I could always us an existing line. But I don't really want to loose any bucket control on my FEL.
mrutkaus said:I would not try to T an existing line and put in a quick connect, I don't believe it is that simple.
Get a remote kit and install it; see my current post with pictures on installing the remote kit.
Mike
ajflyfishing said:The cutter is something new to me (Samurai Sabre), the web site is Saber Samurai.. File attached.
According to the book: To function correctly, the Samurai requires 0.4 to 1.0 hp (0.3 to 0.8 kW). The hydraulic oil flow required at an operating speed of 250 rpm is 3.3 gal/min (.21 L/s). Hydraulic pressure during normal operation is less that 500 psi (3 450 kPa). A hydraulic pump supplying at least 5 gal/min (o.3 L/s) should have adequate flow to operate the Samurai . Most tractor and equiment hydraulic systems can easily supply this oil flow with out affecting the performance of other hydraulically driven components.
Sorry about being long winded. I would like to T off one of the existing lines and add a quick connect, but not sure.
dfkrug said:Plumbing all the way to the front from the rear remote valve is a mess
