Price Check I need a price check for aTC 26DA
   / I need a price check for aTC 26DA #1
kcook
Platinum Member
MI
Cub Lawn Tractor
Looked at an TC 26DA with 12LA loader and 60" mid mount mower and ine Sigle remote. All for $19595. To high, low any addvice.
KC
   / I need a price check for aTC 26DA #2
That sounds high to me.
I paid $15,200 for a new TC24DA HST w/12LA in April 2005. Assuming the remote adds $ 200 and the MMM $ 2,000 would put you at about $ 17,500. Maybe they increased the price $2,000 from the 24 to the 26? Seems like a big increase though for 2 hp.
   / I need a price check for aTC 26DA #3
The TC26 took a price jump over the TC24, personally I love the tractor but I think that NH priced them out of the market. For what it is worth, the price range I've seen on the single rear remotes is typically running $350 to $500 give or take, depending on brand, and always cheaper to order the tractor with one than to have the dealer add it later. The NH MMM deck is also more expensive than most brands, I'd peg that closer to $2500-$3000 installed.
I can't understand the new prices on the small New Hollands, their larger units are competitive, and their TZ series are competitive, but the class 1 TCs are, unfortunately currently priced at a premium. Very nice tractors, higher capacity than virtually anything remotely close that size, probably worth the money if you really need the capacities and PTO hp in a small machine, but I have a feeling sales are going to drop for NH on these tractors.
   / I need a price check for aTC 26DA #4
Just an FYI... a TC26 is a TC24 running at higher RPM's. There are some great programs on the TC24 right now that make it more attractive.
   / I need a price check for aTC 26DA #5
<font color="blue">
Just an FYI... a TC26 is a TC24 running at higher RPM's. </font>
That is what I understand, but I was also informed that they had to alter some of the gearing so the engine produces more HP at higher RPM but is also producing the maximum PTO hp possible by altering something in gearing? Essentially if you just turn up the rpms, you get more hp but you are not able to bring up the PTO hp and still hold the PTO to 540 if they don't change things down in the PTO transmission. At least that is what I understood the sales guy to say at the local dealership.
   / I need a price check for aTC 26DA #6
I have also priced the TC26DA and was quoted about 1000 less that you were....from other posts on here that i have read, for 1500-2500 more you can get the same configuration, mmm, the fel has more lift capacity (14la), ....go up to the TC33DA....that is the bang for the buck, that is probably what I will go with when I finally get one..I have compared all the numbers between JD, Kubota, and now Cub Cadets 7530, and 7532...It will either be blue, or the Cub....only thing with the Cub is that it doesnt have mid PTO, and the Fel lift capacity is much lower....900, as opposed to 1200+ on the 14la....The cub is a nice tractor though, and would work for me...I'll be running a RFM...
bottom line, for the price, I have ruled out the TC26DA that I initially was going to go with.....
good luck and keep us posted! /forums/images/graemlins/smile.gif
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2008 New Holland B110 MFWD Loader Backhoe (A52748)
2008 New Holland...
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
