I need a mower jack
   / I need a mower jack #1
vanguard
Bronze Member
Raleigh, NC
2014 Kioti DK45SE
I have a pair of 72" zero turns and a 32" riding mower. One of the zero turns is diesel so it's pretty heavy. I'd like to buy a jack that I can use to service all of them.
I don't want to throw away money on a $450 jack, like this one, but if that's the right tool for the job I'll do it.
So, do I need that or can I buy something cheaper and more "shade tree" mechanic oriented?
Edit: Another option is the FEL on my tractor but I want something safe enough to crawl underneath. My family would be doomed without me.
   / I need a mower jack #3
I lift my mower deck all the way up.
I then jam in a long 2x4 (or whatever) between the frame and the mower deck, and use the board as a lever to lift the entire mower up so that its weight is mostly on its rear wheels. I normally rest the other end of the board on the back of the high chair or work bench.
I also use anti-seeze on the bolts holding the blades on, so that they can be removed with a cordless impact gun. Doing this stuff has greatly eased the servicing hassle factor of getting at my zero-turn's blades.
Any other thoughts?
   / I need a mower jack #5
Since I have a lighter weight ZTR, I have the slightly smaller, cheaper MoJack than the one in the OPs link. I use it to clean the bottom side of the deck and to remove the blades. I also have one of these farm jacks:
Strongway Farm Jack — 3 1/2-Ton Capacity, 5in.–40in. Lift Range | Farm Jacks| Northern Tool + Equipment that I use if I just want to lift the front wheels to remove them to grease them. If I were going to get under it with the farm jack, I'd sure want something to hold it up and make sure it wouldn't fall.
   / I need a mower jack #6
I use my roll around cherry picker jack to lift my riding mower front end to remove/sharpen blades. The cherry picker gets a lot of use for other lifting chores as well; such as engine removal, unloading heavy items from my trailer. The boom pole on my tractor would also work, but I can finesse the cherry picker lifting/lowering better.
   / I need a mower jack #7
How about using your FEL and building a sort of jack stand for safety? I am guilty of using the loader without support, but will be making some sort of stand soon.
Will
   / I need a mower jack #8
I've used the FEL with a strap to lift the ztr and then set it on jack stands. I've also used my friends lawn mower jack. The lawn mower jack is worth every penny with the ease of use, safety and convenience.
Will
Doh! This is perfect. I'll lift the mower, set the frame down on the 12 or 15 ton jack stands I already own, and it will be safe to work on.
6-Seater Electric Golf Cart (A44572)
6-Seater Electric...
PALLET OF CUTTERS (A45333)
PALLET OF CUTTERS...
2014 Volkswagen Passat Sedan (A42744)
2014 Volkswagen...
2002 Honda CRV (A44501)
2002 Honda CRV...
2021 John Deere 5055E Tractor (A44391)
2021 John Deere...
2013 Audi Q7 Premium Plus AWD SUV (A42744)
2013 Audi Q7...
