I need a loader control valve
/ I need a loader control valve #1
duksrule
OK so through some help on this board I have figured out that my LCV is leaking internally. I also need some hard parts for the valve joystick that I can't find so I am thinking about just replacing the entire valve and being done with it. I would like to stay in the $200 range. I found this one LV22RFSTKAB at surpluscenter.com but it doesn't mount flat the way I need it to. If I mounted it flat with the lines coming out the top like I need, then the up and down for the loader would be side to side on the stick. I talked to the tech folks at surpluscenter.com and they said that you can't swap the vavle internals to make what I need and they don't have anyting that would work.
Can someone point me to the vavle I need??
I need a valve that mounts so that all of the lines come out of the top and the up/dn on the stick is up/dn on the loader and then side to side is bucket roll. It is going on a JD 4200 with a woods loader if that matters and it is not a JD valve that is currently on it.
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
John Deere XUV825E (A61307)
John Deere XUV825E...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
Adams 5 Ton Fertilizer Spreader (A63118)
Adams 5 Ton...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
