I just learned a valuable lesson
   / I just learned a valuable lesson #1
anthonyk
houston texas
Century 3647
Ok, it's time to admit I did something stupid /forums/images/graemlins/grin.gif
I store fuel in standard 5 gallon plastic containers from Home Depot. I have both gasoline and diesel.
I also have one for the mixed fuel I use in my Husqvarna chainsaw. That one has gas mixed with oil, which looks remarkably like old diesel.
AND I had a extra container of old diesel which I'd left on a back part of the property. I'd been using it to start some brush pile burns.
Well, I brought that old diesel back in a few weeks ago and wouldn't you know, I filled my chainsaw up with it.
Yep, good and full. /forums/images/graemlins/smirk.gif
Boy did that thing smoke! And I had oiliest chain you've ever seen.
After figuring out what I'd done I was amazed that it even started and ran.
I cleaned the whole saw and ran a tankful of clean gas and an additive through it, and now it seems fine, but I've learned a lesson.
Today I go down to buy some YELLOW containers for the diesel
Anthony
   / I just learned a valuable lesson #2
I mark all my fuel cans with a Sharpie marker. ie GAS, 38:1 mix for Poulan weedeater, 16,1 for Craftsman saw, etc. I started this after my wife trashed a weed eater by running straight gas in it /forums/images/graemlins/frown.gif
I do the same with old fuel and oil containers.
Ben
   / I just learned a valuable lesson #3
I use red cans for gas, and the yellow cans for diesel. For 2-stroke, I use a 1 gallon can. It has a big stripe of duct tape all the way around it, with 2-stroke written on it too. I run the same premium gas/oil mix for all(Husky 50:1 oil). Kinda wish there was a green can or something for 2-stroke though...
   / I just learned a valuable lesson #4
I only have four types, Regualar gas, Premium gas, Diesel + crud, 2-stroke mix. The Premium is in its own 2 gal can and marked prominently "PREMIUM". The 2-stroke is in the ony 1 gal can (unmarked). Regular and diesel/crud are in 5 gal. Neither marked.
I am hoping that the next prowler spots the diesel/crud can to run off with. I leave it parked temptingly close to my throwaway chainsaw (the two good ones are hid out) It is used for starting brush piles and starts as 4 gal diesel then all oil drainage, gas used for parts cleaning, paint thinner etc is added to it as the year progresses.
Having both diesel and gas in 5 gal cans not clearly distinguishable is dangerous. I was expecting to hear a story of filling a diesel tank with gas.
Harry K
   / I just learned a valuable lesson #5
I do the same as slowrev, Mark it all with a sharpie... When I need tanks next time I will also look for the yellow ones for my diesel...
   / I just learned a valuable lesson #6
I have different fuel containers of the politically incorrect color for what's in them. I like it that way 'cause *I know* what's in them. I didn't plan it that way, it's all the store had at the time. I had a builder grab one and empty a couple gallons of diesel into his gas powered power trowel. Serves him right, but it was running, just smoking a lot. I had another two containers stolen out of my pole barn. I hope they got poured into the wrong engine, too. /forums/images/graemlins/smirk.gif
   / I just learned a valuable lesson #7
I have matching Biltz cans for gasoline, diesel, and kerosene. Only difference is the color-- red, yellow, and blue.
They look so nice sitting on the shelf with the exact same size and shape! I don't see the blue ones for sale at very many places though.
   / I just learned a valuable lesson #8
I am just amazed that your wife runs a weed eater. I will never have to woory about my wife ruining a weed eater unless she drives over it with the car or something.
   / I just learned a valuable lesson #9
I too go the sharpie route. I have small one gallon cans for the chainsaw and the weed eater. They used a slightly different mix ratio from one another, so I write the mix ratio on the cans also, as I can never remember what the proper ratio is. If it werent for the markings, I'd never get it right!
   / I just learned a valuable lesson #10
Dang.
I need to mark and get color coded containers. Maybe I'll do this as a New Years resolution. Maybe not. /forums/images/graemlins/grin.gif
With all these replies, I guess it is a matter of time before I mix up, all my containers are 5 gallon red, from the same manufacturer. My 2-cycle, is a one gallon, however.
Hmmm... what to do...
-Mike Z. /forums/images/graemlins/grin.gif
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
6 ROLLS OF CONDUIT (A50854)
6 ROLLS OF CONDUIT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
