I hit my flagpole with my front-end loader
   / I hit my flagpole with my front-end loader #21
Mine got bent under similar circumstances. The single point of contact methods will dent the pole. I filled it with sand and parked it on some soft grass. Then I drove on the high spot with my front truck wheel. It got most of the bend out of it. To make it look ok and keep the flag flying, I stuck an iron pipe in the ground recepticle and pushed it to a small angle. This canceled the remaining lean. Now the pole is vertical at flag height and the kink/offset is at ground level and considered to be a 'feature'. Mine is a 35' tapered aluminum pole ($2000) so simply replacing it with a new one and hiding the damage to the gift was not a realistic option!
   / I hit my flagpole with my front-end loader #22
I would reset the footing in the ground to compensate for the bend. You'd have a one of a kind flag pole with a lot of character! :D....and I'm sure it would be a great conversation piece(probably already is?). Put some landscaping around the pole so you don't accidently hit it again. Put a schrub on either side of the pole and groom them to follow the bend in the pole. :rolleyes:
Don :)
Thanks, for all the suggestions. I am planning on fixing it this weekend. So I'll let everyone know how I make out. Thanks again, eddy622611
   / I hit my flagpole with my front-end loader #24
What? no pictures of the blunder ?;)
   / I hit my flagpole with my front-end loader #25
eddy, Could you get someone to turn a wood plug on a lathe & drive it into the pipe? MikeD74T
2382 (A60432)
2382 (A60432)
17307 (A55853)
17307 (A55853)
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
UNUSED FUTURE PC71-71" HYD PLATE COMPACTOR (A60432)
UNUSED FUTURE...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
