DJP
On the dash panel on the left side, there is one panel that shows temp with a range of 221>>>240 with a F in the middle of the gauge range, as I am running my tractor with the bush hall, the hand on this gauge goes over to the middle on the F after running/cutting 30 min's or more, is this normal, or is this a sign that my tractor is running hot for some reason. I have a two blade bush cutter(handy 600 ?) Could it be that my bush cutter is set too low while cutting, that is making this temp hand go over to the middle on the F. Is there anything else I can check to see what may be causing this temp hand to move over to the F.
