I have a hydraulic leak
   / I have a hydraulic leak #1
Root Cause
Platinum Member
North Carolina mountains
Mahindra 2638
I have had a small leak at the oil filter seal for some time. Very slow and figured I would address it when I change the filter.
But now I am seeing more oil on the ground. I traced the leak to what looks like a very small set screw (could be an NPT or some variant) that is near the bottom of the transmission a few inches below the oil filter. Looks like a 4mm allen wrench will fit it.
When I wiped away the grime, I saw a sliver of pipe tape. :unsure:
I bought it with 80 hours so someone along the way band-aided as best they knew how.
Hoping someone here has a better way of sealing it without retapping it to a larger size. I can do that as a last resort.
I am pretty sure pipe tape was a bad choice but not sure of better options at that temp right on the tranny.
Ideas appreciated.
   / I have a hydraulic leak #2
Root
Have you tried tightening the plug? Might be that simple to stop the leak. Just use your judgement on how tight is tight. Teflon tape is only a problem if wrapped past end of fitting or when removing and reinstalling a fitting.
Thanks O for replying.
Yes, i did tighten it as much as I thought I could. My main concern was teflon tape not being a good solution for this heat or this pressure so thought I would see what else would be better.
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52748)
Adams FL24...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
International 284 Tractor (RUNS) (A50774)
International 284...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2015 Ford F-550 4x4 Knapheide Service Truck (A50323)
2015 Ford F-550...
