I have a bobcat CT 122 burning the 18 gauge ground up on trying to start
   / I have a bobcat CT 122 burning the 18 gauge ground up on trying to start #1
Dales tractor
Bobcat ct122
I have a bobcat CT 122 tractor that is burning the 18 grit gauge ground up on trying to start
   / I have a bobcat CT 122 burning the 18 gauge ground up on trying to start #2
Welcome to the group. You didn't say what the ground wire went exactly. A good start would be to clean and confirm the condition of the chassis / engine grounds. If they are tough to get to or seem lacking, run new ones, just not near sensitive modules etc.
   / I have a bobcat CT 122 burning the 18 gauge ground up on trying to start #3
Welcome to the TBN. Based upon the fact you say it's a ground wire I'm going to guess one end connects to the frame. To what is the other end connected?
   / I have a bobcat CT 122 burning the 18 gauge ground up on trying to start #4
18 Ga. would be for something like panel lights or a radio. Certainly the battery to ground wire is larger. Like 4Ga. or similar. Check the battery terminals and where the battery ground wire attaches to the engine or frame. Both ends need to be shinny where they connect.
The fuse for that 18Ga wire should be no more than 10A. Most likely less than that in practice. More detail is needed.
By the way, welcome to TBN! (y)
   / I have a bobcat CT 122 burning the 18 gauge ground up on trying to start #5
Something not right here. A ground wire goes from neg post on the battery to the tractor or engine frame. It is short and about as big around as a pencil. Or larger.
But an 18 gauge wire is only as big around as a pencil lead. It will burn up. Too small.
   / I have a bobcat CT 122 burning the 18 gauge ground up on trying to start #6
It sounds like the main battery ground cable has a bad connection, either at the frame mount or the battery terminal. The 18 ga. ground is probably for the instrument cluster and the starter is trying to ground through it. Cleaning up the neg cable should sort it.
   / I have a bobcat CT 122 burning the 18 gauge ground up on trying to start #7
You know, I like that explanation and admit I didn't think of it. But I have seen instances where there is a smaller gauge wire next to the larger gauge wire going to a battery connection. It's usually done on the positive side, but I suppose it could be done on the negative side.
I can't see any electtrical reason why it would be done that way, but if the original poster says that he has both a large and small wire connected to the negative (ground) side of the battery then dan's explanation that the larger wire is not making good ground contact to the tractor frame sounds correct to me. Check both the battery end and the frame connection for the large ground wire from the negative terminal. I have seen instances where the wire is corroded through inside of the insulation as much as an inch back from the battery, so check that heavy ground wire carefully.
Galvanized Livestock Gates (2x Gates) (A55218)
Galvanized...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
2014 John Deere 244J (A47477)
2014 John Deere...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
