I hate grease zerks
   / I hate grease zerks #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I find that the grease nipples on my L3400 Kubota's loader to be a real pain to get grease into from time to time. I've resorted to using a needle attachment on my grease gun for most of the zerks.
Last night when using it on a particularly stubborn nipple, on one of the loader pins that holds the bucket on, I broke the grease zerk off the pin. This is the second one I have broken - same loader pin!
Anyone else struggle with their grease zerks like this? How do you deal with it without cussing?
   / I hate grease zerks #2
Why are they breaking? Is it because they're hard to get to? Do you have the end of your gun set for the right tension?
   / I hate grease zerks #3
I did not know that they were adjustable:eek:. Please enlighten me on how. I also have a problem on some nipples where it is difficult to remove the gun after greasing.
Cityfarma
   / I hate grease zerks #4
The tip that plugs onto the zerk nipple on my grease guns will unscrew and loosen, so it does not grip the zerk as tightly. I guess there are larger zerks out there and the gun will work on them as well.
I discovered this by accident and went huh, would you look at that.
Mark
   / I hate grease zerks #5
I broke one fitting when my loader was new, since then I haven't had a problem with them taking grease or getting the grease gun off the fitting.
I use a straight manual gun with the solid pipe, I find that the grease gun with the solid pipe is easier to get on and off the fittings.
   / I hate grease zerks #6
I broke a zerk on a hard to reach snowmobile suspension. Really made me mad and I was talking to a friend about it. He asked me if I had the end too of the gun too tight...
So I learned the hard way that by twisting the end of the grease gun fitting thing, you can make it easier or harder to put the gun on the zerk... and thus break off less of them!
   / I hate grease zerks #7
You can also buy little plastic caps for the zerks if environmental exposure is considered a problem (in this case, it doesn't sound like the problem though).
Hmm. There may be a heck of a lot more about grease zerks and grease guns than I ever imagined.
I have a flexible hose on my gun. I have two types of fittings for the end of the hose. One is a regular type of fitting that is cylindrical and fits over the grease zerk. The other is a needle fitting - basically a long needle with a small hole at its tip that the grease come out through.
The cylindrical fitting is annoying for two reasons. One is that it is often hard to take off the grease zerk. Sounds like I am missing some way to adjust it - to loosen/tighten to make it fit individual zerks and to come off easy? Please elaborate so that I understand correctly.
There are 4 pins that connect my loader to the bucket. I find that the cylindrical fitting is too big for me to fit over the zerks in those pins. The pin s are a cylindrical piece of steel - probably 3/4" in diameter. The grease zerks are on the outside of each pin. The end that has the zerk is concave so that the zerk is sort of embedded into the pin.
As a result I tend to use the needle fitting for almost all of the loader zerks.
I'm guessing that I broke this zerk because for whatever reason its hard to get the grease in there and I probably pushed down on the zerk too hard or hit it on an angle with the needle fitting of the grease gun.
I'll play around with my grease fittings to see what I can find. Perhaps I will find a smaller size cylindrical one that will fit over the zerks in the pins without having me resort to using the needle fitting.
I think that using a solid pipe might also help - will get one and try it out.
   / I hate grease zerks #9
No grease gun I've ever used (Lincoln, etc.) had an adjustable fitting on the tip to control the "snugness". Sounds appealing. What makes/models have that?
   / I hate grease zerks #10
I can't stand Zerk fittings; but I know they are a necessary evil with machinery. I use a flex-hose on my Lincoln 12V gun, and I have the best luck removing the hose by pulling it off the Zerk in a similar fashion to using a claw hammer to remove a nail. However; there are about four fittings on my JD 420 loader where the access port is small and I have to wiggle them off in a straight line pull with the Zerk center-line.
Some of my fittings are so awkward to get to, that a flex-hose is the only option.
2010 PETERBILT 367 HOT OIL UNIT (A53843)
2010 PETERBILT 367...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
23311 (A51694)
23311 (A51694)
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
