Loader I forgot what's inside the horizontal KL130 arm, leak
   / I forgot what's inside the horizontal KL130 arm, leak #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
Might have been going on for long time but just noticed a tiny hydraulic leak dripping from each bottom end of the KL130 add-on replacement brace.
That is, something inside the hollow tube is leaking.
But I don't remember what is in there, probably just two screw together connectors for the hoses?
Mike
   / I forgot what's inside the horizontal KL130 arm, leak #2
Yes there are 6 or 8 junctions in there connecting the Hyd lines. Take the access plate off and most likely one fitting just needs tightening so I would check them all. Do not get close to it at all while it's running, since high pressure hydraulic fluid leaks(spray) can penetrate the skin very easily and cause a host of bad health problems.
Wow, 6 or 8 connections! I don't rememberthat. For me it's not just the cover plate now, it's a 70-lb 25 screw 'cover' for it designed to stop the cracking.
Thanks for the info. I think I might wait a while!!
Mike
   / I forgot what's inside the horizontal KL130 arm, leak #4
Naaah, if it's leaking, I'd go in and fix it. I might be remembering wrong on my CK30, but it's at least 4 connections in there.
Ok I'll move it up the list. Thanks.
Mike
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
2017 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2017 FREIGHTLINER...
BUYERS PREMIUM & PAYMENT TERMS (A52141)
BUYERS PREMIUM &...
