I broke my carb on j/d 214
   / I broke my carb on j/d 214 #1
wenailem1
:confused2:
Hello everyone, i'm in some trouble, long story short, leaky carb,change gasket, easy fix, no, bowl bolt strippped tapped it broke the cast inside here main needle goes, locate new carb 3 wks later, not a kohler, but a walbro,install it,fires up, it has 3 adjusters on it, cant seem to dial it in, its a k321aqs motor, the new carb is off a newer motor with identical #'s however the # inside the carbs are different, the old is 30 m and the new is 60 m. im also concerned about running lean and blowing up my motor. one last ? there is a aluminum gasket between the valve cover and the head, are they reusable, or can i make a gasket and add to the aluminum one. turned out to be a long story. thanks guys
any input?
   / I broke my carb on j/d 214 #3
Sounds like a question you should post on Weekend Freedom MAchines. everyone on there drives old tractors. I have a 214, but have no insight for you. Good luck!
Thanks, I'll check that out.:thumbsup:
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
2025 Epic Electric Golf Cart (A51694)
2025 Epic Electric...
Hyster H225E (A47384)
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
