Hyundai generators
   / Hyundai generators #1
ericher69
Veteran Member
Ontario Canada
2008 Kubota b2920
Anybody have any experience with Hyundai Generators from Walmart; more specifically the 7250W 13hp model?
Save your breath if you are giving your opinion and do not own one!
I am a home owner in an urban center and require occasional power back up for my home; 1-2 times per year for a few hours
   / Hyundai generators #2
Those 3,600 r/m screaming generators at Wal-Mart are really expensive for what they are. You can get the identical generator in yellow for less at many other outlets. They are reasonably quiet for intermittent use.
I operate a 12 mW power plant as my day job, so I think I'm qualified to speak. I also have a 3.5 kW Champion, and two Onan diesel generators, 6 kW & 12 kW resp.
Generators - Champion Power Equipment
Will look into the Champion generators.
Thanks for the advice.
I priced a Honda today and...$2500+tax for less watt output
Walmart Genny $850+tax (I could buy 3 of these for 1 Honda) yeah I know they are not in the same league.
   / Hyundai generators #4
Whatever you buy, be sure it has a 240 Volt output and the special plug to take full advantage of it.
A lady from our church just bought a generator and it only has 120 volt output, so if she connects it to her home wiring through a transfer switch she will only be able to use 2400 watts, even though the generator is rated for 3850...
   / Hyundai generators #5
Look at the Briggs and Stratton generators...... They have a good price and can get Lp models for 12kw fairly cost effectively
Will do
My local TSC has a Champion 9000w for $699+tax
2019 DODGE RAM 2500 HD SERVICE TRUCK (A51406)
2019 DODGE RAM...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
Ford 18in. Stock Rims (A53117)
Ford 18in. Stock...
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A51692)
2018 Ford F-250...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
