On the smaller tractors the hydraulic pump is frequently located at the front of the engine being driven from a pulley on the front of the crankshaft. You may find it tucked under the alternator. Follow your hydraulic lines. I get replacement pumps for my old Mitsubishi from eBay. I have found the same physical dimension pump may spin either direction depending upon the tractor using it so I must shop carefully for the correct one.
