Hydrostatic transmission question
   / Hydrostatic transmission question #1
Mapp
I have a Mahindra 2615 HST 4wd with fel. Today while working on my land, a limb struck the underside of the tractor and caused my transmission line to start leaking at a rubber hose connection. I got the tractor back to the shop in short order with very little fluid loss. However by the time I fixed the leak, I lhad ost a good bit of transmission fluid so I went ahead and drained the entire system. Unfortunately transmission fluid was all over the place under the tractor. Therefore, I cranked the tractor for about 20 seconds in an attempt to simply move it forward about 3 feet not knowing if there would be enough fluid left in the system to do this. When I pushed the reverse pedal nothing happened but when I pushed the forward pedal I heard a grinding noise and the tractor did not move. I immediately turned the tractor off. Again all of this took place in about 20 seconds. Did I do any harm to my transmission?
   / Hydrostatic transmission question #2
I doubt you did any damage, fill the system with fluid again and try it. I believe it will be fine. Good luck!
   / Hydrostatic transmission question #3
You should be OK......Actually it's a good idea to run the tractor for about 30 sec with the drain plugs out. This will clear out the residual fluid.
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
UNUSED AGT H15R EXCAVATOR (A51243)
UNUSED AGT H15R...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
Land Honor Skid Steer Blank Plate (A50514)
Land Honor Skid...
2020 CATERPILLAR 308CR EXCAVATOR (A51242)
2020 CATERPILLAR...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
