Hydrostatic trans / rear end locking up
   / Hydrostatic trans / rear end locking up #1
Chilly807
Elite Member
Nova Scotia
Kubota L3400DT
We have a 2006 Craftsman 23 HP lawn tractor with a hydrostatic transmission. Every so often, several times a year it "locks up" solid and refuses to budge either ahead or reverse. After letting it sit for a few hours or overnight it will move again, and it's fine til the next time, which may be a month later, or the same day.
I can't tell if it's the transmission or the rear end, other than replacing the transmission does anyone have any ideas for a fix?
Sean
   / Hydrostatic trans / rear end locking up #2
Parking brake is sticking in the on position. Next time it does it look down around the front corners of the transmission and you will find a lever with a rod hooked to it. Try moving the lever and see if it released. You will hear a click if it was stuck and released along with a quick movement of the lever in the opposite direction that you pushed it. If that is what it is a good lube with some penetrating oil should fix you right up.
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2019 John Deere 204L (A47477)
2019 John Deere...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
