Well this is the story. I have a 1969 IH 2544. Its like a 544 international but the yellow industrial version. It has hydrostaic drive foot pedal design. Whe it is hot and runnuing at rpm like haying in summer it barely wants to go. In the winter its absolutly mint and anytime i use it it goes good except after a few hours of haying in hot weather 80's and the temp guage starts going up and the tractor starts getting slower. Ive talked to a few IH mechanics and they all seem to think like me that the hydostatic tranny is warn out. Now, its gonna be around 3k to fix from what i understand. have to split tractor and tear all apart and rebuild pump and hydraulic motor and gonna be expensive. I would like to get another a year out of it or two if I could then buy another tractor. It has power steering and hydro drive and pto and 3 point hitch. I run hy-tran hydraulic oil in it, the regular stuff you would get at a IH dealer. I have changed the oil around 600 houirs ago i guess but changed filter last year. A couple people have said to try a heavier oil and that may help it get by a couple more years. one of these guys rebuilds hydrostaic drives and hydraulics for a living and his only concern was something about brakes but i think my brakes are dry no fluid. It makes sense that heavier fluid will help because in the winter at 0 degrees it goes great because oil is heavy and thick so heavier oil should help right? Another IH service mechanic said heavier oil will make porblem worse but he is only one that said that. I would like to try it if you guys think it may help and need to know how thick i can go and what type or viscocity i should get. i dont know what regular hy-tran is 30weight? or less but i would like to go thicker unless someone can think of another way to get a couple more years out of it without rebuilding it. i am also thinking about flushing both radiaters out good for better cooling and maybe replacing the rubber hoses for tranny cooler incase there collapsed or something. But I want to discuss weather heavier oil may help and what to use. i want the heaviest you think i can run without damaging anything. thanks for listening. i know soundguy will jump in here hehehehe
Mike
Mike
