Hi
I‘m planning on building an articulated loader myself (from scratch).
I want it to have 4wd hydrostatic drive.
So my first thought was to just take a pipe, put a gear onto it, thread it though 2-4 ball bearings and drive it using a hydraulic engine via a chain.
Should be quite easy to build, but would mean that it would have 2 permanent locked axles, which shouldn’t be to much of a problem, since it is meant mainly for off-road use, but once you are on concrete, it would be a dumb idea or put a lot of stress on the axle and rubber on the ground.
So the next idea was to go the CadTrak route, 4 drive motors. Could go the same way as above, but use 4 short axles or the CadTrack way with the engine mounted straight onto the wheel/axle, which sound quite interesting and would solve a couple other problems.
I don’t have the CadTrack plans, so can maybe someone tell me how it is done there, or if my plan would work.
Atm I thought about making the drive train like that:
On one side mount a wheel hub to the axle, thread it through 2 Ballbearings (welded to the frame, to take up the weight and to guide the axle) and mount the hydraulic engine with a keyway to the other side, to drive the axle.
Any major flaws in the design (or maybe non unederstandable what i mean and i should make a drawing)?
