Hydrostat vs Shuttle
   / Hydrostat vs Shuttle #1
boostmg
Pennsylvania
Branson 3620 TLB Hydro
Hey guys .. I enjoy mechanics ... and i was watching the tail end of a video on a branson tractor, and the owner said he got the shuttle shift b/c he didn't like the idea of the hydrostat using the same hydro fluid as the hydraulics. He admitted he doesn't know if it's a big deal, but he personally like the idea of the shuttle shift better for that reason.
I didn't realize that's how the hydrostat worked, but it makes sense.
So I'm just wondering if that guys concern is a real concern. He was saying the fluid gets hot, etc. In my mind if the hydro fails then also your trans fails. For this reason the shuttle being a separate system does make sense.
So how about it, for reliability does the shuttle offer any more reliability? Or is the HST good to go?
   / Hydrostat vs Shuttle #2
21 pages for your entertainment.
   / Hydrostat vs Shuttle #3
The shuttle transmission also uses the same hydraulic fluid as the hydraulics
   / Hydrostat vs Shuttle #4
The HST models have an additional oil cooler in front of the radiator.
On my 3725H with the non factory rear remote there is an oil line with constant flow in it just past my elbow. When I am working the tractor hard I can feel it get warm but not too hot to touch.
I think the Branson 20 series shuttle uses the manual clutch. The biggest possible maintenance issue would be wearing out the clutch. That will depend on operator skill and what the tractor's used for. The HSTs seem pretty bulletproof, I've not heard of anyone having a problem with them.
   / Hydrostat vs Shuttle #5
Yes, but not hydraulic pressure to run the transmission, only to lubricate the gears.
HST tractors loose 2-4 PTO HP due to parasitic loss from the HST
I read through that entire thread and watched some comparison videos.
The branson Shuttle shift still has low, medium, and high right?
Because i previously thought the shuttle would give me more gears, but it seems like the biggest difference is just the way you move forward or backwards ... clutch + column shifter vs front and back pedal.
   / Hydrostat vs Shuttle #7
Yes the Shuttle still has the three ranges plus the 4 main gears. Making it a 12x12 transmission.
The 2021 models, like the 3620, 4820 and 5520 have a 4 range synchronized transmission plus the 4 main gears, also synchronized. Making it a 16x16 transmission.
Yes, you still need to use the clutch to go back and forth and to change gears but once you get used to it, it's such a natural movement, you barely notice it.
ok i didn't realize it had the 3 ranges + 4 main gears ... that makes sense.
i wonder if i would be one of the people that gets the HST and then wishes i had more fine tuning ability with the shuttle.
   / Hydrostat vs Shuttle #9
There is 50+ years worth of equipment with hydrostatic transmissions and shuttle shifts transmissions. Both are great, each has a purpose it is better suited for, get the one you want, keep good fluid in it and enjoy.
   / Hydrostat vs Shuttle #10
I'm lost following this;
The shuttle is a manual transmission with a range transmission and a main transmission yielding 12 or 16 gears.
The HST is a hydrostactic transmission with either a 3 or 4 speed range transmission being feed from the hydrostatic unit which is an infinity variable transmission. With the variable transmission you have an unlimited amount of "gears", with the pedal just barely depressed the tractor would be just barely moving kind of a first gear, as you continue to depress the pedal your tractor should go faster, halfway down you should be in about your middle "gear" call it 5th, as you continue to depress the pedal when you reach the maximum travel you are now in high "gear" call it 10th,.
For simplicity do not use linked throttle but advance your hand throttle to say an indicated 2000 engine rpm;
start depressing the forward pedal just a bit and the tractor will move slowly,
depress the pedal a bit more and the tractor will go faster with no change of engine rpm,
continue depressing the pedal and the tractor will behave as a higher gear the further the pedal is depressed.
Releasing the pedal and allowing it to return slightly will return you to a lower "gear" your tractor will go slower,
all of this will occur without changing engine rpm or the hand throttle position.
This will happen in every range untill your "gear" selection with your pedal is to high of a "gear" for your horsepower.
I see many questions on the operation of the hydro's especially with the linked throttle were people tend to think they can drive them like a car with an automatic transmission and they will try and shove the foot pedal to the floor thinking it will give them the maximum power and it will not as it is actually the highest "gearing" the transmission has, whereas backing of the foot pedal and advancing the hand throttle will provide a much better response.
2014 KENWORTH T800 MIXER TRUCK (A50854)
2014 KENWORTH T800...
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
Landoll Hauloll (A51039)
Landoll Hauloll...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
