hydrostat vs gear hp loss
   / hydrostat vs gear hp loss #1
radman1
Elite Member
midwest
JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
I am considering moving up to a hydrostat cab tractor. Does anyone know the amount of drawbar/rear wheel HP loss for a hydrostat compared to gear drive. I have a Kubota 3710 GST and dealer said expect to lose about 20% in pulling power with hydro. He recommended an increase from 37hp to 46hp (ie. 4630) to have the same pulling ability with hydro. This would suggest considerable power loss. Most bigger tractors talk about drawbar hp in specs but don't see this in the compacts. Is this because of so many hydro's in the compact class that companies don't want to show specs with lower drawbar hp for hydro tractors with the same engines?
   / hydrostat vs gear hp loss #2
i dont think its 20% but im no expert, if in doubt just get more hp. i have a freind that just got a john deere bull doser the size of a D-6 cat and its hst and powerfull enough to do anything. as best i can understand an hst is a hydrolic pump running a hydrolic motor, to me that sounds like the perfect transmission, but im an aircraft mechanic so i can relate to that better than clutches and gears.
   / hydrostat vs gear hp loss #3
Oh boy.. here we go. This is one of those hotly debated topics like synthetic oil vs dino oil.. etc.
The easiest way for you to compair power loss between 2 tractors is to go get the specs for a bunch of units that come as both gear, and as HST.. and then see what you get.
Yes.. there is some loss on the hst.. Even though I'm a gear man... I think 20% sounds high. though i don't have any info to refute -or- support that statement.. etc.
For pulling.. one other thing other than drawbar hp may com ein to play... the relief setting ont he drivetrain. There have been limited reports of people's relief's opening 'early'.. thus not getting optimum power tot he ground..
IMHO...I believe this to be a mantenance / adjustment / repair issue.. not a design flaw..
soundguy
   / hydrostat vs gear hp loss #4
I have a Mahindra 2810HST and if I remember correctly there was about 1.5hp lost to the pto vs gear. As far as drawbar hp, mines heavier than some others in it's hp class and with loaded rears it'll still spin the tires in 4wd if it meets an immovable object. What more could it do? I think soundguy might be onto something regarding relief settings, we've read about it before on TBN.
   / hydrostat vs gear hp loss #5
Years back, International Harvester marketed a few bigger, higher horsepower farm tractors with HYDRO trannies. They didn't catch on like one would have thought. I recall reading in a farm magazine at the time of tests done, measuring the "in-efficiency" of a hydrostatic tractor. The "testing" was very informal, and as I recall, done in such a way as to get the results that the "tester" was looking for. In other words, they wanted the hydro to "fail". Where they found the biggest weakness was in heavy drawbar loads. (pulling primary tillage tools. i.e. plow, chisel plow, ect) The "failure" or highest levels of inefficiency was after a few hours of sustained work, after the hydro's fluid had time to really heat up.
Once any product or concept has a "bad name", that reputation may never go away. Now consider the fact that I own gear drive tractors with the exception of a John Deere 265 lawn tractor. (17HP/48" cut/hydrostat tranny) I don't feel that I'd gain any advantage with a hydro (full sized) tractor, but you can't beat the convenience of hydrostat when working in tight quarters that requires constant speed changes and direction changes. Also, with the rising popularity of hydro, the concept has seen constant improvement.
To attemt to answer the question posed in the original post, I doubt the measureable inefficiency is more than 1 or 2% initially. (as an average. certain brands and/or models may vary slightly) Maybe "if and when" the tractor in question has done a days work plowing the north 40, that may read higher. Go mow the pasture and it may well read the same as when you drive it off the dealers lot.
You have to gauge the inefficiency of power delivery against the efficiency of power used in a given time. In other words, in the hands of most compact, subcompact, or utility tractor buyers (in todays market) a hydro is a better choice. Easier to operate, less wear and tear (over a clutch), faster "cycling" when used in let's say, loader work, and every bit as long lasting as most any gear transmissions (when cared for and used properly).
Long and short.... It's just a numbers game. A 35 HP gear tractor and a 35 HP hydro tractor should be an even match for work accomplished when you consider all factors. The tiebreaker would be "which one is easiest to operate". Game/set/match to the hydro.
I honestly believe that most people "over-rate" the specifications on tractors. It's not so much "about the numbers" as some manufacturers would like you to believe. To me, it's "How much". How much does it cost? How much will it do? and how much time will it go before it wears out or breaks down?
Modern gear trannies are a world away from older designs. They aren't the balky old crash boxes they used to be either. It's all about what you're used to and what you feel most comfortable with.
Just like eating ice cream. You can have chocolate, strawberry, or vanilla. Your choice. No one can tell you which one YOU like.
   / hydrostat vs gear hp loss #6
On multiple posts within this forum only 1 to 2 HP loss is ever mentioned. If it truly was 20% there would be a hay of alot more gear compact tractors out there. I think the Dealer wants to sell you a bigger tractor.
Vic
   / hydrostat vs gear hp loss #7
The additional 1-2 HP loss is for PTO HP, not drawbar HP as the original poster asks about. Here is an excerpt from an article I read the other day:
>>>>The University of Nebraska’s Tractor Test Laboratory, which started in 1920, tests every new tractor sold in the United States that’s rated at 40 hp or greater to verify claims about horsepower and torque at the PTO. They also evaluate other criteria, like fuel economy and noise level. “PTO horsepower is usually about 75 to 85 percent of gross engine horsepower,” says Brent Sampson, test engineer with the University of Nebraska. “When looking at tractors, make sure you are comparing apples to apples ... that you are comparing PTO horsepower to PTO horsepower, and not engine horsepower to PTO horsepower.”
The third place horsepower is rated is at the drawbar. A tractor’s ability to do tillage work, like plowing and disking, is affected by its drawbar horsepower. The actual drawbar horsepower is 75 to 85 percent of the PTO horsepower. <<<<
If the dealer is correct that there is an additional 20% power loss with hydro then instead of a 75 to 80 percent loss that one would expect from PTO HP to drawbard HP, the more realistic numbers would be 60% to 64% with the hydro.
One must also keep in mind that the initial power loss would be great going from engine to pto HP, thus creating a greater differential when going to drawbar HP.
Let's look at a 40 HP tractor for example, using the 75%-80% losses as a basis for the gear and hydro respectively.
Gear: PTO HP 32; Drawbar PTO 24-25.6 HP
Hydro: PTO HP 30; Drawbar PTO 18-19.2 HP
As you can see the PTO HP differences aren't really enough to be concerned with, but the drawbard PTO, which is basically the power the tractor has to pull, is considerably different.
For a lot of people the drawbar HP isn't going to be a factor, but if someone uses a plow, or other ground engaging impliments it will make a difference. With jobs like running a rototiller, rotary mower, etc., the HP differential is so small that it doesn't amount to a lot in terms of which tractor to get.
   / hydrostat vs gear hp loss #8
If you use the figures quoted above, your figures are wrong. They would be more like...
Gear: PTO HP 32; Drawbar PTO 24-27.2 HP
Hydro: PTO HP 30; Drawbar PTO 22.5-25.5 HP
A long way from 20% difference :confused:
   / hydrostat vs gear hp loss #9
Here's a quote from Colorado State's website that cites a direct head to head on gear vs. hydro. This test is about 30 yrs. old and the advice is just as good today as it was then. Hydro efficiency may have gone up over the years, I would be surprised it's gone down. This supports the accepted 10% loss at the drawbar for hydro vs. gear.
"Another interesting comparison can be made using the maximum available drawbar hp at 100 percent load and the maximum PTO hp. A ratio of the drawbar hp to the maximum PTO hp is an indicator of the efficiency of the drive train of the tractor. Consider Test Nos. 1255 and 1257 for an IH 986 diesel with 16-speed transmission and IH hydrostatic diesel 186. These tractors have identical engines, producing approximately 105 PTO hp. However, the standard transmission 986 produces 90 drawbar hp, while the hydrodrive produces 80 drawbar hp.
The comparison of drive train efficiencies is as follows. IH 986: 90/105 = 86 percent; IH 186 hydro: 80/105 = 76 percent. The tractor with the standard transmission has less loss in the drive train and is able to transmit more power to the drawbar. The overall fuel efficiency with the standard transmission is obviously better. In this case, the potential buyer would have to decide whether the advantages of the hydrostatic transmission were worth the increase in fuel consumption and efficiency."
For those intermittant times when I need every hp the engine can muster directly on the ground, I'll accept the fact my equipment will require me to work 10% slower than a geared one would...for that moment. I think the time will be more than recovered when the load lightens. If my work included a significant amount of ground tillage, then that's a whole different story.
   / hydrostat vs gear hp loss #10
The figures quoted in the article are for gear tractors. The dealer told the guy that Hydro has an additional 20 percent drawbar HP loss, which is probably pretty accurate. My figures included that additional 20% loss. That means a tractor that normally has the drawbar HP 80% of the PTO HP has a drawbar HP that is 64% of the PTO HP.
Why the loss? Because of the power transference from engine to drive wheels has a greater loss with hydro transmissions as opposed to gear transmissions.
In the Nebraska tests of IH's with identical engines and hydro and gear transmissions respecively there was a 10 HP difference in the drawbar HPs between the gear and hydro transmissions. That clearly indicates that there can be a significant difference in hydro and gear drawbard HPs.
http://www.ext.colostate.edu/PUBS/farmmgt/05007.html
DHE 38-7 API 5' ALL PURPOSE PLOW (A50459)
DHE 38-7 API 5'...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
42in Hydraulic Forks Forklift Attachment (A49346)
42in Hydraulic...
2014 Ford Expedition SUV (A50860)
2014 Ford...
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
2016 John Deere TS Gator Utility Cart (A49346)
2016 John Deere TS...
