Hydrologic help
   / Hydrologic help #1
L_Nicholson
Madison, Indiana
1998 JD 4400
Since Im new at this I figured I would pick some brains before I start digging into my hydraulic problem.
I have a 1998 JD 4400 Hydro with 330 hrs on it. I was recently driving tee posts in with the FEL and the next day noticed the FEL was performing at about half the speed and strength. Ive checked the fluid level and that seems to be ok and next I was going to check the screen but wanted to see what else it might be.
Any ideas would be greatly appreciated!
Lee
   / Hydrologic help #2
Remove and reconnect all 4 of your FEL quick-disconnects.
   / Hydrologic help #4
Lee, can you tell us exactly how you were "driving tee posts in with the FEL" It might give us a clue to help you...
   / Hydrologic help
I tried to unplug and plug the disconnects today and noticed the other hydraulic motions improved..... dumping / curling the bucket seems normal and the 3pt hitch and the belly mower would all move about the way they should but the up motion still has a problem.
I was driving tee posts by pushing them about 3 inches in the ground (by hand) then taking the FEL and placing the edge of the bucket on the post and pushing down the loader. The ground wasn't real dry so they seem to slide in fairly easy. I've been doing this all season long and have driven about 60 posts this way.
   / Hydrologic help #6
Whew! I had visions of you using the FEL like a pile driver -- repeatedly slamming up and down on the post. Thanks for the clarification.
   / Hydrologic help #8
A good possibility is that the insides of one of the hydraulic quick couplers went bad.
I had a similar problem about a month ago.
You can narrow down which one is bad by seeing which function is slow (raise or lower), then trace your lines.
The quick coupler half that is attached to the tractor is the one you are looking for - there is a ball/spring/seal in there, and the spring can go bad and make the ball restrict the oil flow.
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A51039)
2022 Gravely...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
