Hydrolic problem
   / Hydrolic problem #1
jdannels
I need help - I have a TL2500 Iseki, which has been great so far. However, this evening my wife was driving and when she went to lower the front bucket it went up instead of down. Now the bucket will not dump or retrack, but when you try to lower it - it goes up and when you try to raise it goes up. Also where do you put in additional hydraulic fluid in case I have to once the problem is solved. Any help or suggestion is greatly appreciated. j_dannels@yahoo.com or collect 775-475-0803
   / Hydrolic problem #2
Your 3 point lever is lifted to high and the 3 point is at the top trying to go higher. Push your 3 point handle down till the engine stops straining and the loader will work.
Buck
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
7022 (A50322)
7022 (A50322)
