hydrolic oil location
/ hydrolic oil location #1
tim blay
coffs harbour
tn95fa
hello
i have a new holland tn95fa 2005 model
is the hydrolic filler location at the back of the tractor where is looks like the back diff is located (there is a dip stick there) .does the two run off the same oil
thanks for the help
/ hydrolic oil location #2
yes the trans/hyd fluid fill is rear of the tractor. When filling with oil pull dip stick out this will prevent the gurgling of the oil when you pour
Wolverine Quick Attach Dozer Blade (A66285)
Wolverine Quick...
Straw Mulcher (A65579)
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
(12) SKLP SK-LJB-12 Polyethylene Pads (A64127)
(12) SKLP...
90in. Work Bench (A65640)
90in. Work Bench...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
