Hydro whine: 600 hr thoughts
   / Hydro whine: 600 hr thoughts #1
HomeBrew2
Banned
Dunlap, CA
Kubota BX23
Did my 600 hr service today.
(My BX23 is supposed to get the hydro oil and filt changed ea 300 hr.)
For the last, maybe 50-100 hrs I've been thinking the hydro seemed to be whining louder than I thought I remembered it did when new. I poo poo'd that thought.
Imediately after the service, I noticed a marked reduction in the hydro whine ... close to night and day ... maybe, dusk to high noon.
Not sure what to think. I didn't notice any diff at the 300 hr service. But, I did work her a lot harder the 2nd 300. No appreciable chips in the sump screen ... ever. I might feel a little more power to the wheels. Pretty subtle if true. Dunno.
Maybe I'll change the filter at 150 hrs. next time. Maybe do the whole shebang at 200 hrs. ...
Cheers!
   / Hydro whine: 600 hr thoughts #2
Maybe was a little low on fluid. You would have topped it off when you refilled.
Similar to power steering whine when low in a car...
-JC
   / Hydro whine: 600 hr thoughts #3
-JC
   / Hydro whine: 600 hr thoughts #4
Brew...I noticed a reasonable reduction when I went from UDT to SUDT. Did you happen to change oils (specs/brand)?
   / Hydro whine: 600 hr thoughts #5
DD, You have a point, though I'm pretty sure I checked it when I found the whine to be more noisy. Also, I usually got jerky feedback in the steering wheel when PS fluid low in car.
Jim, no change in oil ... Kubota SUDT.
   / Hydro whine: 600 hr thoughts #8
Most likely the filter was starting to get plugged. Not uncommon to have the filter start to plug up prior to the recommended service interval.
   / Hydro whine: 600 hr thoughts #9
Thanks for confirming one of my thoughts. Sounds like you have experience with this. Would you recommend changing filters at the 1/2 way mark of fluid change?
Cheers!
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
1 pallet of pipe (A53117)
1 pallet of pipe...
2011 Ford F-550 Iowa 1015 3,200LB 1.5 Ton Crane Mechanics Truck (A51692)
2011 Ford F-550...
