Hydro-Tran fluid for 2615HST?
   / Hydro-Tran fluid for 2615HST? #1
stem1955
Flagstaff AZ
Mahindra 2615 HST
Hi,
I have a Mahindra 2615 HST (bought Jan 2009 with 120 hrs as a dealer demo from Flagstaff Equipment, now has 180 hrs). It's a great tractor:)! Tractorbynet is also a great resource for me as a first-time owner. I've been reading these forums for months and have learned a lot, but this is my first post.
My question--I bought some NAPA 85-405 Premium Heavy Duty Tractor Hydraulic & Transmission Fluid to top off my transmission on advice from NAPA parts guy. According to the can, It "meets JD J20C, Quatrol Case IH, Hytran Plus MF Permatran III Specs". Is this fluid OK to top off my Mahindra HST? When I do a complete change of fluid, is it OK to use this?
My 2615 HST came with a Land Pride BB2560 box scraper, and FEL ML106. I have added a Value-Leader (Hanmey) slasher brush mower 42" SL-110 bought from Betst on ebay, and it has worked well too. I go thru a lot of #2 shear bolts for brush mower due to rocks and buried metal--see note about metal below, but I get them from HomeDepot bin for 11 cents each, so no big deal. I also have a nice home-made harrow for grooming our arena thanks to previous owner of our property.
I use my tractor for manure management from our 4 horses, arena grooming, brush mowing (5 acres, mostly grass and tall wildflowers--RockyMountain Bee flower), snow removal (150x50 ft driveway in Flagstaff, EL 7000'), moving dirt and cinders around, making drainage swales, pulling fence posts, helping to build our pole barn, etc. The 2615 has been very sturdy and reliable--has started no problem at 0 degrees last winter. I also have some heavy chains that I use from draw-bar to drag stuff to my dump/salvage area since the land we bought has lots of scrap metal and wood buried here and there (previous owner was welder/metal worker)--the tractor makes this work much easier. Had to put slime in my front tires to deal with frequent punctures from the metal though.
Thank you for any advice on hydro-tran fluid, and for this forum.
stem1955
   / Hydro-Tran fluid for 2615HST? #2
Mixing has always made me uneasy. Probably just me but you are playing with chemistry and heat. As long as your fluid meets the Hytran spec you are fine. When Cub sold those Mitsu's they quite often would use Hytran instead of the CC fluid. Ther were three dealers in my area and they all told me to use Hytran. I eventually switched to Mystik Royal purple. The spec's were a little broader and I thought my hydro was a touch quieter. Probably just my mind tring to justify the cost of the Mystik though?
Thanks Outlander, I will look into Mystik Royal purple...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52128)
2006 Magnolia Dry...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
