hydro pedal
   / hydro pedal #1
qed-cat225
Sullivan, WI
2011 Bobcat CT235
anyone else have sticking issues with the hydro pedal under load even after proper lubrication? Is this a know issue, my CT225 never had this but can seem to free it up on my newer CT235, not even the dealer
   / hydro pedal #2
Go drive many hours in a dusty/gritty environment and let mother nature and good 'ol wear take some time on it. My CT230 used to do that but not now at 257 hrs.
   / hydro pedal #3
Mine seems to be getting a little better at 150 hours
   / hydro pedal #4
I have 400hrs on my CT230 and my pedal is still sticky. I have tried everything with mine and it is not getting any better. I even took mine to the dealer and they told me it was normal. How can a pedal that sticks be normal? One of these days when I drive it through the house or barn, I wonder how normal that will be?
   / hydro pedal #5
Travel pedal resonse is directly related to amount of charge oil flow, faster engine is running the smoother & quicker the pedal responds. If running the engine at higher RPM doesn't improve the return to neutral and all the linkage is well lubricated, ask your dealer about replacing the dampening cylinder under the platform. This is the cylinder that has the grease zerk on the rod end. Spring inside this cylinder helps keep the pedal from jerking when driving and helps the charge pressure push the pedal to neutral.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
Komatsu WA3801-7 (A50120)
Komatsu WA3801-7...
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
2007 JLG SkyTrak 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
