Hydro Pedal Preferences
   / Hydro Pedal Preferences #1
GreenTime
Bronze Member
North Dakota
JD 110TLB, JD 3720, JD Z997, Kubota L5740
This is for the guys that have multiple configurations. I have an L5740 and have gotten use to the single hydro pedal. I had a JD 2520 with the two pedals before that and really liked them. Now I need another smaller tractor like a B3000. Is it hard to get used to the treadle peddle on a B3000 when you also have a pedal like the L5740? On my L5740 I always use the toe of my foot for forward and reverse (I do not use my heel). Thanks.
   / Hydro Pedal Preferences #2
That's the same way I use mine on the M59 which is the machine we use 99% of the time. Toe to the top of the pedal and then toe to the bottom. No heel on the pedal.
I almost didn't get the M59 because I liked the JD two-pedal set up. And I still prefer the JD set-up..oh well...
Since most of the time is on the M59 I do make mistakes when I get on one of the other machines. But all that happens is that nothing happens. Toe is Toe. So it doesn't make a difference. It might if I was going in the other direction.
rScotty
   / Hydro Pedal Preferences #3
I kind of like the two pedal versions. However, I do not see the single pedal versions that big of a deal. Every tractor is different anyways, just need to mentally reset your brain when you hop onto a different machine.
   / Hydro Pedal Preferences #4
If I were designing my own tractor, I like the side by side arrangement. However, not a big deal to me either way. I've gotten used to the treadle on the KB, a small trade-off for the rest of the rig being so nice to use.
   / Hydro Pedal Preferences #5
I've owned 2 tractors, both Kubota HSTs. I prefer a single pedal. I'm guessing this is 60-75% because it's what I started out on. I'm guessing that would be the case for most operators, you develop a preference to what you start with. I'm sure I could adapt to JDs 2 pedals just fine eventually.
Personally I find a single pedal forward & backward slightly more intuitive than 2 seperate ones. However go pedal(s) were one of the least important factors in deciding what to buy. I looked at JD hard both times but felt Kubota was just better bang for the buck. I looked at TYM & LS the 2nd time & seriously considered them. I can't honestly remember if they were 1 or 2 go pedal as that wasn't that relevant to me.
   / Hydro Pedal Preferences #6
I prefer the two pedal arrangement, and I hate the design of the single pedal on my L6060.
The servo assist pedal would be fine if they had designed it such that one could rest one's foot on it and heel/toe but this is not possible without quickly tiring out ones leg.
Not all single hydro pedals are equal.
SDT
   / Hydro Pedal Preferences #7
I've never owned a small John Deere so I can't offer an opinion on the 2 pedal design.
The treadle on my MX5800 is very similar to my previous four Kubota HST's so I assume it is fairly similar to the B3000.
I also assume the treadle on my L6060 is similar to your L5740.
Both treadles are similar in operation and can be used with the toe only.
When twisted around in the seat while backing up, both treadles can be used in a similar way.
The only real difference is the clearance between the treadle and the sheet metal deck support. The clearance is much greater on the L6060 and I find it easier to use with my toe when operating in reverse.
Obviously, this is a matter of opinion though depending on individual use. There is a bit of a learning curve between the two treadles when switching tractors but so far, it hasn't caused any mishaps.
I hope this helps answer your question.
WOW! Thanks bdhsfz6 for the great reply and photos. I really appreciate the time and effort put into your explanation.
   / Hydro Pedal Preferences #9
I have used both the single and the twin pedals. My current tractor has the twin pedals and it is great. My previous tractor had the L shaped single pedal, and it took me about a day to get used to it and i thought it was great. When I got the Kioti with the twin pedals, it took me about a day to get used to it, and I think it is great. I other words, I don't think it makes any difference... at least it doesn't to me.
   / Hydro Pedal Preferences #10
I've been using a Kubota treadle set up for the past 7 years. Toe for forward and heel for reverse is quite simple to understand. I never need to check foot placement.
I'm sure I would learn to use the side by side set up also but I'm still waiting for the John Deer dealer to call me back. It's going on 8 years now.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2015 Dodge 5500 4X4 Bucket Truck (A53472)
2015 Dodge 5500...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2017 Club Car Carryall 1700 (A51573)
2017 Club Car...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
2023 UNVERFERTH 632 LOT NUMBER 178 (A53084)
2023 UNVERFERTH...
