hydro or power reverser
   / hydro or power reverser #1
area123
I'm buying my 3320 this week and can't decide between the ehydro or the reverser. The price difference is $800. I'm used to a collar shift on my previous compact tractor so either one will be a nice upgrade.
I will have a loader but won't do much more than maybe using it as a wheelbarrow for planting trees, an occasional bucket of dirt, etc.. No heavy duty gravel spreading or unloading, etc. The other main uses will be grading my driveway, leveling my new yard, some tilling for gardening, etc. And quite a bit of finish mowing eventually.
Should I save the $800 and get a nicer attachment or is the hydro really worth the extra money. I've driven both and will have to get used to the reverser. I like the hydro but doesn't seem like its worth $800 to me.
   / hydro or power reverser #2
Then it probably isn't. I will never buy another non HST, but everyone is different.
I guess one way to look at it is it worth the gamble when you are spending this much money? Only you can tell; good luck and enjoy your new tractor.
   / hydro or power reverser #3
I believe that the power reverse will give a little more power, as it is direct drive once engaged. I have two of them (my 5420 is actually up for sale now) and once you get used to not using the clutch, it is very versatile. On my tractors the reverse is a little faster than forward, so it takes a little getting used to. When you switch to reverse, the tractor speeds up.
Another nice thing about the power reverser is that you can switch into neutral without using the clutch as well.
For finish mowing, I do prefer the hydro. For mowing larger areas, the power reverse works just great.
I will be driving mainly, and my 17 year old son but he's used to collar shift as well. My wife won't drive it. We do have a lot of trees that I like to mow trails in but as far as finish mowing around the house I will do mainly w/ a rider and then will probably finish mow 2 acres w/ the tractor along the driveway & outside the yard around the trees.
One thing I didn't mention is that I do plan to brushhog about 40 acres about once per year as needed and I will spray with my 3pt sprayer the same ground. It is a previously overgrown pasture that I am trying to turn into a nice hay meadow but I don't plan to mow and spray forever or do any haying w/ this tractor for sure. I did brush hog the whole thing with my smaller 790, twice and it did just fine other than taking about a month of weekends.. but it was heavily overgrown w/ honey locust, blackberries, sumac, etc..
   / hydro or power reverser #5
area,
Everything you listed says hydro to me, no. Tilling, mowing, brushhog, planting trees, trails.... Hydro, hydro, hydro, hydro, hydro.
Having infinite speed control always at your feet is worth the money for any pto or precision job required. It completely changes the tractor.
A lot of us grew up on gears and the new reversers are REALLY nice and they really have their place, but it's a pretty small group of hydro users who want to go back.
You'll be glad you got the hydro.
Joe
   / hydro or power reverser #6
Another vote for the hydro, very good for back and forth movements such as boxblading and general uses. I don't think you will regret it.
   / hydro or power reverser #7
I'd vote for the reverser transmission. More power to the wheels and a very easy transmission to use. Much more versatile then the hydro, especially for that 40 acres to mow. Unlike a hydro (unless you get the cruise control), you just set the range, gear, throttle and direction and go.
Also, it is 800 bucks cheaper...find another implement to buy.
I'd just test drove a reverser yesterday, in fact. Used machine, so it's not the power reverser...definitely a nice, robust transmission. And yes, I'm thinking about trading the 790 for it.
I do wonder how many of the folks responding to this thread ever drove a gear transmission...
   / hydro or power reverser #8
I have four geared units and one has a shuttle shift. I no longer farm just FEL work, bush hogging, box blade and such with plowing and disking for food plots.
I have three HST units.
   / hydro or power reverser #9
I vote with Roy Jackson.
I have the power reverser and was accustomed to a shift tractor before. I like being able to select the gear and then pull the throttle down for "cruise control".
Have you tried a hydro for more than a couple of minutes? I think this is a personal choice and you should find a way to use each option for at least an hour on the same kind of job. That way you will be able to make the right decision for you.
   / hydro or power reverser #10
I have had over 14 gear tractors, 2 shuttle shift and a hydro. For tilling, lawn mowing, snow removal or loader work I would pick the hydro hands down. No question.
I preffer the shuttle transmission for max HP applications like heavy box scraping, plowing or bush hogging tall grass.
I think it all comes down to you specific needs.
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
MONITOR WITH BUILT IN COMPUTER (A53843)
MONITOR WITH BUILT...
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
2020 KUBOTA RTV...
