Oil & Fuel Hydro oil
   / Hydro oil #1
nightrodjc
04 Deere 4610 E-hydro
Anyone use any other brand oil then jd10 or 20 in these E-hydros, I have the 4610. Thanks Jim
   / Hydro oil #2
Welcome to TBN. Bunch of smart tractor minds here! (Me, I'm just behind...and tryin' to catch up!)
Check out the oil, lubes and fuel forum here on TBN. Got info/discussions for everything that's carbon based (or not) that you might want to put in your tractor.
AKfish
   / Hydro oil #3
Personally, would keep the receipts for all the lubes in case warranty issues crop up and stay away from anything close to an off brand for the 3 years. Unless you want to go back to the dealer and then it is not an issue. Just did a fluid change and it is pricey, but piece (whoops) peace of mind is worth it.
   / Hydro oil #4
I'm running the AMSOIL "Synthetic Tractor Hydraulic/Transmission Oil
SAE 5W-30 (ATH)" in my 2210. I have 250 hours on the tractor and 200 hours on the oil everything is working great. (Time to change it again at 200 hours.)
Here's more information: AMSOIL - Synthetic Tractor Hydraulic/Transmission Oil, SAE 5W-30
This oil meets John Deere J20C & J20D specifications so it should work fine. Mines not an ehydro, so I checked the 3X series owner's manual online and it calls for J20C - then I checked the 2210 manual and it lists J20C as well.
Good luck!
   / Hydro oil
Thanks for the info guys, deere had 15% off sale this week so I picked up all my filters and oil :eek: $$$. This is my first hyrdo C.U.T. and I got it used so if a problem shows up I wont have to ? the fluid. I have used TSC oil in my gear deeres and never had a problem. Jim
   / Hydro oil #6
I have looked at the TSC oil before and I'm pretty sure it is listed as meeting the JD spec on the side of the bottle. However, I seem to recall TSC has multiple oils and you'd want to make sure you get the right one.
Yes...the JD oils are never cheap...sticker shock...but they do work well.
2013 John Deere 6105D (A50120)
2013 John Deere...
Steiner VA242 Post Hole Digger (A50774)
Steiner VA242 Post...
Electric Golf Cart (A50121)
Electric Golf Cart...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
White 255 Disc (A50774)
White 255 Disc...
2013 Chevrolet Sonic Sedan (A50324)
2013 Chevrolet...
