hydro oil check?
   / hydro oil check? #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
When you guys top of the hydro oil do you bring it to the top of the line or keep it in the middle on the dip stick. Mine is pretty much at the very top of the line. I dont know if that good or not. Also you check the top of the dip stick not the back side? thanks
   / hydro oil check? #2
I put mine at the top mark of the dipstick with the loader bucket sitting flat on the ground. That level moves quite some bit with the amount of fluid that goes out to get the loader to lift so as long as it's between the marks with the loader down it should be fine.
   / hydro oil check? #3
You should check your hydro fluid with all external cylinders collapsed. Always when looking at the dipstick go by the lowest line of oil weather it is on the front side of the stick or the back. I always keep mine a touch below the full line for expansion when the oil gets hot. To much oil in the system can cause you to blow out seals.
   / hydro oil check?
I spoke to the dealer they said go by the high end of the dipstick which on mine would be the front side. If i went from the backside the level on the front would be halfway up the dipstick.
   / hydro oil check?
Can anybody confirm what's correct? Front or back of dipstick when checking? Dealer told me front ICU812 Says back
   / hydro oil check? #6
"Keep the level between the marks" per Operator manual. Not below the low side on front or above the high side on the back.
   / hydro oil check? #7
Does it make a difference hot or cold when checking?
geo
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
(4) 12' Steel Gates (A50515)
(4) 12' Steel...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
