Hydro Oil Capacity
   / Hydro Oil Capacity #1
mjonesnh
Platinum Member
Tennessee
TC34DA
Have a 2007 TC34DA that I finally got around to changing hydro fluid in today. Owners manual says 8.8 Gallon. Drained all 3 plug locations and fill matched amount that drained out. At best 6.5-7 gallons brought it to fill line. HST filter was changed but left the main hydro filter on as it only had a few hours on it. 3 point arms let all the way down but front bucket was curled onto it's cutting edge
which was an oversight on my part.Even allowing for maybe a quart in the hydraulic filter plus what was in the bucket cylinders I cannot figure out the discrepancy between what manual calls for vs. what it actually held. Fluid had been changed before by the dealer but first time I had done it so not sure if this is normal or not. Maybe 2 gallons short minus amount in hydraulic filter and bucket cylinders. Any thoughts?
   / Hydro Oil Capacity #2
I would run the tractor and use the loader and 3ph for an hour or two then check my dipsticks. I wouldn't be overly concerned over a little of the previous oil still hanging around, that stuff lasts forever. Remember that stuff, to quote my uncle the refinery manager, "is a few million years old". There is some older oil in the filters, the lines, pump and wherever keeping your tractor from needing the total 8.8 gallons. No big deal. If I sold oil I'd tell you to change it annually and the little bit of older stuff will do irreparable damage. I don't sell it so I say hogwash. I probably have 70 or 80 years on various Ford, NH, and Deere tractors with much less than recommended interval hydraulic fluid changes.
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A52748)
2017 KINZE...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
