Hydro Oil 2
/ Hydro Oil 2 #1
timkins
Fishers, NY
Cub Cadet Model 2542
Is it OK to change the filter and just add an equal amount of hydro oil to refill to the full mark. In checking my records there is only about 200 hours on the existing trans oil.
/ Hydro Oil 2 #4
Dixie Chopper told us to use Mobile 1 5w-30w
/ Hydro Oil 2 #5
Yes, if the tractor is stored indoors and kept dry. Hydro oil sees no corrosive combustion blow-by particulates, and the primary degrading factor is usually moisture picked up from sittig outdoors.
Many run the same hydro oil for 10 years at a time, with no issues. In fact, I think the ATF I dumped out of the hydro unit on my last Cub Cadet 123 had been in there at least 40 years, and still looked really good. Very minimal "jelly" in the bottom of the diff.
I change the hydro oil in my tractor on the specified interval, which I think is about 600 hours, but I'd need to go pull my files to confirm. I change the hydro oil in my log splitter every 10th year.
The reason you change your engine oil once or twice per year, even if accumulated hours are way below specified interval, is to flush out potentially-corrosive compounds that collect in the oil due to piston blow-by, not because the oil itself has lost any desirable physical properties.
/ Hydro Oil 2 #6
Actually the depletion of the additive package in quality hydraulic oil (not the cheap TSC junk either), depletes from the heat-cool cucles the fluid goes through.
Hydraulic oil (quality stuff) will have moisture dispersants as well as seal conditioners in it and those degrade with heat-cool cycles and need to be renewed at certain intervals, those intervals specified by the particular manufacturer of the unit you own.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2016 JCB 507-42 TELESCOPIC FORKLIFT (A60429)
2016 JCB 507-42...
Viewz VZ65UHD 65in 4K Security and Signage Monitor (A59231)
Viewz VZ65UHD 65in...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
2014 Forest River Rockwood Premier 2317G S/A Pop Up Trailer (A59231)
2014 Forest River...
