Hydro leak...TC24DA
   / Hydro leak...TC24DA #1
TCBoomer
Platinum Member
CT
New Holland TC24DA
About a month ago, I posted a thread about splitting my new tractor to fix a hydro leak. I received the authorization and started the task. Here are a few shots...
another shot
split in half...
another view
and another shot
the source of the leak...
According to the manual, the throw out brg hub is threaded. If this is true, then I need to find a 1 1/2" OR 1 1 9/16" crows foot or maybe there is a special tool from New Holland? It appears there is enough room to unthread and remove the hub, and then I can replace the input shaft seal, which is leaking. If this isn't possible, then I'll have to remove the charge pump housing to remove the hub.
Anyone know if I can remove the hub without removing the case?
   / Hydro leak...TC24DA #8
Uuhhgghh! I feel nauseous - like I'm watching one of those surgery shows on the Discovery Channel.... /forums/images/graemlins/crazy.gif
Guts and gore.... /forums/images/graemlins/grin.gif
You sure are brave! BTW, nice clean tractor. I'm sure that makes it easier to work on.
Mark
   / Hydro leak...TC24DA #9
Egads! That's a lot of parts. /forums/images/graemlins/crazy.gif
I was wondering just the other day how it was going with your machine. I'm glad you are on your way to getting it fixed. I hope you don't end up with any parts left over. /forums/images/graemlins/tongue.gif /forums/images/graemlins/crazy.gif
   / Hydro leak...TC24DA #10
Talk about ACE Mechanic. Holy-Ring-Molly......I had my own (limited) visions what splitting a Tractor meant....but that's insane. How in the world are you going to get it together again......it's all in pieces. My hats off to you. That's one incredible task that you undertook. Don't think there are many on this forum besides maybe RickB that would attempt the sheer madness of it all !!!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
JLG ELECTRIC MANLIFT (A52472)
JLG ELECTRIC...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
Cat TH407C Telehandler (A52748)
Cat TH407C...
2012 MACK CXU PINNACLE (INOPERABLE) (A52472)
2012 MACK CXU...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
