Houkie
According to the manual on the 2210 how to check your hydro fluid you should have your little tractor cooled down or cold, park it level, with implements DOWN ( rear PTO) and look at the level of your hourly glass on the back of your transmission. It should be 2/3 full, but not below the half way line.
From the factory the hourly glass was always full: cold/hot/ implements up or down/ not leveled and even new other models sitting at the JD dealer have the hourly glass completely full.
Recently after 440 hrs. After some hard mowing it spit some hydro fluid out of the breather tube ( see other post in this forum with pic). Not knowing how much was lost during this time, I filled it up according to the manual and see the tip of the hourly glass empty, but what my concern is, is this really the level I should have, because with implements UP I don't have anything in hourly glass and on level or operating the glass is empty. Although for the moment all works fine. What would be the first sign if not filled enough? Loader not moving or what else? The 2210 has no reading of temp. On dash. Anybody that knows how much more to add after glass is full on 2210?
Of course you could drop all fluid/filter and measure, but I'm afraid even then I might overfill thinking not all hydraulic lines would empty up, before refill.
