Hydro fluid in motor oil?
   / Hydro fluid in motor oil? #1
Jethro
Bronze Member
Eastern NC
Kubota B1550, several Exmark ZTRs, Walker GHS and a 1967 Craftsman Surburban
I checked the oil in my Kubota B1550 this morning before using it, and it was at the full mark. After running it for several hours, we noticed that oil was dripping from the breather tube. I checked the oil and it was thin, lighter, and well above the full mark (about twice as deep on the stick as full should be). It doesn't smell like diesel, and it is not milky looking. The coolant is not low. The hydro oil is about 1/2 way to the full mark. I didn't check it before using it today. Can the hydro oil get into the engine from the power steering? I cant think of what other fluid it could be. If so, do you have any recommendations for repair?
   / Hydro fluid in motor oil? #2
From power steering no, from the hyd pump shaft seal.
(APPROX 15) 6" X 2" X 68" TUBING (A54756)
(APPROX 15) 6" X...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
UNUSED JCT 2 PRONG BALE SPEAR (A54757)
UNUSED JCT 2 PRONG...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
Ford Pickup NR (A50323)
Ford Pickup NR...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A55787)
2025 GIYI Stump...
