Hydro fluid for 2135
   / Hydro fluid for 2135 #1
brian_b
Just changed Hydro fluid in my 2135. I didn't realize until I completed the change :eek: that the fluid the dealer sold me is 737-3054. The manual calls for 737-3025. Is this an issue?
   / Hydro fluid for 2135 #2
That should be the correct fluid. I beleive that 737-3025 is a Case part number.
Bob B.
   / Hydro fluid for 2135 #3
You did receive the right drive oil. The part number changes and they gave you some of the old part number oil.
Sorry guys, my first post is incorrect. I reversed the part numbers.
737-3054 was the original hydro fluid (labelled "Drive System Oil").
737-3025 is what I just put in the transmission.
The 737-3054 oil was only $10.25/gallon (still have the price tag on my old container, which has the old oil in it). Oh well...
   / Hydro fluid for 2135 #5
The 737-3025 hydraulic/transmission fluid(has red stripe on label) is NOT the oil recommended to use in a 2000 series. The 2000 series need the Drive System Oil (blue/yellow stripe on label). These two oils are not compatible to mix with each other.
   / Hydro fluid for 2135 #6
This is an interesting question....
I have a Cub Cadet 1864, and ordered some maint items for it yesterday, including hydro oil.
The Cub part numbers don't pan out any longer. What they are sending me is called "HyTrans" or something like that.
Does this sound right?
-Larry
   / Hydro fluid for 2135 #7
That's Hy-Tran and is a reddish colored oil that was used in the older hydrostatic drives. The newer ones call for Drive System Plus, which is a synthetic oil and around $35 a gallon
Bob B.
   / Hydro fluid for 2135 #8
I have a CC GT 2544 and it calls for 737-3120 trans fluid. It costs roughly $8 a qt.
   / Hydro fluid for 2135 #9
Wow. It sucks to be new hehe :)
-Larry
Bob B.
   / Hydro fluid for 2135 #10
Hey Brian,
I also have a 1998 HDS 2135 Cub. Penzoil, mult-vis 20W-50 is same exact fluid. Fram also makes a transmission filter but I forget the #, I changed mine about a year ago.
Good Luck!
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2017 Hitachi ZX245USLC-6N (A47477)
2017 Hitachi...
2015 Skyjack SJ 4626 Scissor Lift (A53117)
2015 Skyjack SJ...
