Hydro Drive Question
   / Hydro Drive Question #1
rims421
Eastern CT
new holland tc- 35
I have a question regarding the hydro drive on my cub 7275.
I was working the tractor skidding some trees i had cut down.
The tractor would be pulling pretty hard in reverse with a fairly large tree chained to the bucket. At some point with the tractor in mid range 4wd if i encountered additional resistance(like the rear wheels falling into a slight depression)
the wheels would no longer turn. If i put the machine in low range it would begin to turn the wheels again. The machine is operating in a heavy snow crust. Is this normal? I thought the machine should either stall out or the wheels should turn. It does not seam to be a problem going forward. I was going to check the adjustment on the foot pedal for starters. Any other suggestions / advice? /forums/images/graemlins/confused.gif
   / Hydro Drive Question #2
Sounds completely normal to me; just have to change to low range when that happens.
   / Hydro Drive Question #3
I'm venturing into territory here that I'm not quite sure I know enough about, but if I say something wrong, the real experts will jump in and correct me -- I hope.
Here's how I understand it. There is no direct mechanical connection to the wheels like there is in a gear tractor, but a hydraulic motor. As I understand it, a hydraulic motor does the same thing as a hydraulic cylinder, except it makes things go round and round instead of in and out.
Now, think about what happens when you try to lift something that is too heavy for a hydraulic cylinder. It doesn't stall the engine or jump and clatter, it just quits. I assume there is some sort of internal bypass, but I don't really know. The same thing happens when you ask your hydrostatic tractor to move more than it is capable of moving -- the wheels don't spin, the engine doesn't stall -- it just quits. Shift to the lower range and you're doing something to the circuits that multiplies the power but cuts the speed, and it moves again.
Now, that's not to say that you can't stall it; I've had my tractor stall when I ask it to do too much -- in the lowest range. In the higher range, it just doesn't move.
That's not a very technical explanation, but it describes in amateur terms what happens, as I've observed it.
   / Hydro Drive Question #4
</font><font color="blue" class="small">( I assume there is some sort of internal bypass, but I don't really know. )</font>
I think that's a pretty good explanation, Don. And that bypass is the relief valve opening which doesn't really hurt anything if you don't just sit there and keep it open which would tend to make the hydraulic oil get hotter and hotter.
   / Hydro Drive Question #5
Real nice explanation, Don. /forums/images/graemlins/smile.gif
   / Hydro Drive Question #6
Oh Bird! I was hoping you would call it by it's real technical name, the relief "thingy." /forums/images/graemlins/blush.gif /forums/images/graemlins/laugh.gif
   / Hydro Drive Question #7
Jinman,
You obviously did not study spelling during your last year or two of education....the correct technical term would actually be THINGAMABOB.
Don, that was a very well written explanation, much better that I could have provided.
   / Hydro Drive Question #8
Thanks for all the kind words. Only, now I'm going to have to go to Wally World and get a new $6 straw hat in a bigger size. /forums/images/graemlins/crazy.gif
Thanks for the good news.
I did not want to even think about having to deal with a repair to the hydro tranny.
You guys are the CUT gods.
   / Hydro Drive Question #10
Do you know how hard it is to 'splain that to someone from outside the US? I used to work at the company that probably made the CPU in your computer. I worked in a failure analysis lab, and had people from all over the world that worked in similar labs, come in for testing products.
I tried saying"Grab that dohicky over there", just to be a funny guy. It was really hard to explain why I called it a dohicky and how it could be a dohicky and thingamjig depending on who looked at it.
After in depth explanations, some were amused, some not /forums/images/graemlins/wink.gif
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
Auger for mini skid steer (A53421)
Auger for mini...
2014 RAM 2500 (INOPERABLE) (A53843)
2014 RAM 2500...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
