bucksnort1
I'm in the process of changing the transmission fluid on my TC45D. The rear plug came out without much problem and I got out about 7-8 gallons of fluid. The problem is I can't get the front plug to budge. There is no indication of corrosion and I've applied as much pressure as I'm comfortable doing with a breaker bar. The last thing I want to do is twist the plug off! My question is: if I raise the front end of the tractor, can I get most of the fluid out through the rear plug? Thanks for any advise.
