Hydro 84 Diesel Starts but can't increase engine speed
   / Hydro 84 Diesel Starts but can't increase engine speed #1
Ibelyle
IH Hydro 84
Hydro 84 sat idle for about 2 years. Recently I cleaned it up and added fresh fuel and new filters. After several applications of starting fluid, it finally came to life. At first it would stall as soon as I move the lever from the "start" to "run" position, but after repeated restarts it finally stayed running at about 900-1,000 rpm. However, the throttle lever had no effect on the rpm, neither increase nor decrease.
Two weeks later, I returned for another try at starting the tractor. I anticipated going through the same procedure again. Much to my surprise, it started right up, went up to about 1000 rpm as soon as I moved to the run position, a ran very nicely at that speed. But, no more; no less.
Help will be appreciated.
   / Hydro 84 Diesel Starts but can't increase engine speed #2
It really depends on which inj. pump is on your machine.. American Bosch or Robert Bosch/Germany..
If its the AB, remove the side cover window, 4 flat head screws.. you'll see a link that goes under a cover that controls the fuel.. its stuck..
DO NOT FORCE IT.. it'll snap the pin inside..
IF its a RB.. nothing you can do but send it out.. WAY TO MANY shims & springs inside to mess with, if you don't have the experience..
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
Polaris ATV (A50324)
2014 FORD F-150 (A52472)
2014 FORD F-150...
