Hydraulics
   / Hydraulics #1
I-Car Tech.
David Brown
i bought a David Brown Tractor and planning on mounting a loader on it that has DA cylinders for the bucket and SA for the lift i'm trying to figure out what i need to do to make one side of this control valve a SA Pool for the lift ??
   / Hydraulics #2
You can simply connect the unused port on the lift circuit to the Tank port. That way, it won't force the fluid through the relief when lowering the loader.
   / Hydraulics #3
On that valve, it's actually very easy to do that as they offer two Tank ports. One on the side, just under the Power Beyond port, or on the Work port side. A short piece of hose making a loop straight to that port will work just fine.
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
2014 AMADAS SPC-6-36 LOT NUMBER 211 (A53084)
2014 AMADAS...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
