hydraulics
   / hydraulics #1
Anonymous Poster
Epic Contributor
I HAVE A L235 KUBOTA FRONT LOADER THE BUCKET WILL NOT RAISE WITH A LOAD. THE REAR LIFT WILL NOT RAISE UNLESS THE BUCKET IS TRAVELING DOWN. I REPLACED THE PUMP AND THE RELIEF VALVE.THE SUCTION AND ALL LINES ARE CLEAR.
   / hydraulics #2
Sounds like something in the loader valve. I don't know the specifics of that model, but in others I've seen the hydraulic oil passes throught he loader control before going to the 3ph. If the loader control is not passing pressurized oil to the 3ph, then it will not work either.
You could try disconnecting the loader hydraulics. If the 3ph then works fine, the problem is clearly in the loader control.
Good luck
Truck Tool Box (A50774)
Truck Tool Box...
UNUSED AGT TIRE CHANGER (A51244)
UNUSED AGT TIRE...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
