hydraulics wont work on front loader or back lift arm but all others work HELP!!!!
   / hydraulics wont work on front loader or back lift arm but all others work HELP!!!! #1
cfsoutherncharm1
Farmville, NC
Mahindra 2815 HST
I have a 2007 2815 HST Mahindra tractor 4x4wd and I cranked it using it on a job site last week, was running fine, moved it to a spot and parked it. I let down the loader bucket and the box blade on the back. I sent one of my guys to move it and he told me he couldn't get the front bucket to lift up or the box blade to come up. I tried it and nothing, just plain dead in the water! A friend of mine says it is the pump, I called my dealer, and explained it to them, there has not been any noises, squeaking or anything coming from the pump. The time that elapsed from the time I parked it until when I told my guy to move it was probably at best an hour. the handle on the back lift arms just moves with no resistance at all now. Almost like it was broke off. I think that it is something simple but other people say it's the pump... I'm not quite sure what to do now.. Is there a safety switch? We cheked all the fuses, the oil level was a bit low so we added more and still nothing! all fuses and wires checked to be good. The front loader is clicking when you hit the by pass button but I do not have power there either.. PLEASE HELPPPPPPPP I have got to get it moved from the customers yard and I would like to have it fixed ASAP! thanks
   / hydraulics wont work on front loader or back lift arm but all others work HELP!!!! #2
You might loosen a hose from the pump and see if there is any fluid flowing.
A hyd gage would help to see any pressure and help trouble shoot the hyd system.
If the fluid went to low, you might have lost prime.
Is the pump easy to pull and check the shaft?
2000 Ditch Witch 3700DD Ride-On Trencher (A55787)
2000 Ditch Witch...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
2011 Ford Mustang Coupe (A55758)
2011 Ford Mustang...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
