hydraulics won't move in cold weather
   / hydraulics won't move in cold weather #1
countrygirl14
port Huron, mi
kubota m7040
Have a 2012 kubota m 7040, first winter, stored under a building but not completely covered. Any time temp is under 15-20 tractor won't move, hydraulics won't work. Help! Makes it hard to plow snow when tractor won't work! Les than 100 hrs on it.
   / hydraulics won't move in cold weather #2
Does the engine run?
If the engine runs, you don't have any hyd?
If the engine runs, but no hyd, then the fluid may not be suitable for your climate.
If the fluid is marginal, and works when warm. Have you checked for water in the fluid by doing a crackle test where you heat up a spool of fluid and see it it pops or crackle.
Does the fluid look OK?
That's correct, engine runs, no hydraulics. I'm draining some fluid now and will try that. It's original fluid from dealer, SUDT. Thank you
   / hydraulics won't move in cold weather #4
If it has a sump filter, have you cleaned that also?
Not seeing one in the book so not sure :(
   / hydraulics won't move in cold weather #6
My sump filter is located in the hydrostat foot control pivot.
It is a long round filter.
   / hydraulics won't move in cold weather #7
I looked through one of the M7040 hyd sections, and only saw cartridge filters.
There are about 7 or 8 different M7040 configurations.
It's a hd-u if that helps. No sump though. Fluid was milky and crackles...I hope that's all it is! Thank you so much!!!!
Thanks, I read often but never had to post :) hopefully this does the trick!
2010 International Prostar (A47477)
2010 International...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
2017 Ford F-150 Crew Cab Pickup Truck (A55852)
2017 Ford F-150...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A55788)
2015 Ford F-450...
16FT box truck (A53424)
16FT box truck...
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
